02-08-2011 10:55 AM 03-16-2019 03:20 AM 更新
hi,
i have a very simple connectivity
switch ---- ip phone --- laptop
this is my switch configuration
interface FastEthernet x/x
switchport
switchport mode access
switchport voice vlan 2
dot1x pae authenticator
dot1x port-control auto
dot1x reauthentication
spanning-tree portfast
when i connect my ip phone i am getting to vlan 2 but when i connect a PC to the ip phone i am not getting assigned to any vlan even though i have provided both access and voice vlan there.
Is there any configuration to be done on the switch or ip phone so both my PC and IP Phone get assigned to different vlan. Please help me out i am not able to figure this problem.
this is very urgent.. if any1 can help me out.
Thank,
02-08-2011 11:19 AM
try adding 'switchport access vlan x' , where x is the access vlan number for your PC.
02-08-2011 11:23 AM
thanks for the reply,
but i have dot1x running on that port if you can see. so i dont want give that command for assigning it manually.
any other suggestion for making it work?
is there something to be checked in IP phone or call manager for enabling tat port ?? to verify if ip phone pc port is capable of doing this??
thanks,
02-08-2011 11:52 AM
Do you see anything in the switch logs to validate a problem with the dot1x configuration?
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
