Cisco IP Phones Licenses Table
alshahiry
Guys, how are you...
Kindly is there any table for each Cisco IP Phone license under CUCM that I can be based on deciding how many (DLU) and (Seat Licenses) that I can be based on my calculation to fit my needs?
Jaime Valencia
Yes, use the license unit calculator in the licensing menu in CUCM has all that and can do the math for you.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
