06-03-2013 12:15 PM - edited 03-16-2019 05:40 PM
I have an IP Telephony setup with CME version 9.1.I have integrated with Cisco Jabber for both Anroid and Apple Iphone.
Succesfully registered and we can make outgoing calls with cisco jabber.
The issue is that Caller A has 2 phones - the jabber iphone and cisco 7941 which have a shared line 1334. In the event of an incoming call, both phones do not ring simultaneously.
Lets say there are 4 incoming calls - Call 1 will go to the deskphone, call 2 - jabber iphone, call 3 - deskphone, call 4 - jabber and so on.
Please guide how to resolve this issue.
The configuration for the Cisco jabber mentioned below.
voice register global
mode cme
source-address 192.168.0.2 port 5060
max-dn 50
max-pool 50
authenticate register
hold-alert
dialplan-pattern 1 17101... extension-length 4
tftp-path flash:
file text
create profile sync 1333925093221222
voice register dn 2
number 1334
name Javed Jabber
voice register pool 2
registration-timer max 720 min 660
id mac 0037.6DEE.9324
session-transport tcp
type Jabber-Android
number 1 dn 2
description Javed Jab
ephone-dn 35 dual-line
number 1334
pickup-group 1
label Javeed Islam
ephone 35
type 7941
mac-address aefc.564d.8aaa
button 1:35
Thanks in advance.....
Nithin Louis.
Solved! Go to Solution.
06-03-2013 04:52 PM
That is working as design, you have two Directory Numbers configued, one SCCP and the other SIP, those are not related to each other, even if they have the same number configured, so the CME will randomly select what phone to ring, to make both phones to ring, you have to enable Mixed Shared Lines:
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
06-03-2013 04:52 PM
Jorge Armijo
06-04-2013 06:42 AM
Hi Jorge,
Thanks for your reply.Its worked for me.Now I am getting simentiously ringing on both Smartphones and Cisco IP Phones.
But one change we have to do like both ephone dn
Example
ephone-dn 66 dual line
number 1333
name test
voice register dn 66
number 1333
name jabber.
Once again thanks for your effort and it was new information for me.
Best Regards
Nithin Louis.
06-04-2013 06:46 AM
Not a problem!!
Thanks for the rating
Jorge Armijo
