Cisco LYNC 2013 integration with Cisco UC and Polycom
islam.kamal
Level 10
Level 10
I have an integrated solution between  LYNC 2013 , Polycom , Cisco UC . Cisco LYNC (is the maker of the conference (host)) is integrated sucessfully with polycom and it is ok , the problem with Cisco UC. Microsoft LYNC 2013  which uses h.264 SVC have aproblem with cisco UC. I need a good solution to fix the problem between Cisco UC and microsoft LYNC 2013.
http://social.technet.microsoft.com/Forums/en-US/lyncserverpreview/thread/0e377238-05e9-404c-9efa-1937a4ba0806/
Thank you
10 Replies 10
islam.kamal
Level 10
Level 10
Any help please , i will be so pleasure.
Anas Abueideh
Level 9
Level 9
Hi Islam.
it is the same like previous post
A VCS ("Lync Gateway")may be required to interoperate with the MS Lync server. Here is the reference guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Microsoft_Lync_2010_Deployment_Guide_X7-2.pdf
Moreover:
"The addition of the Cisco AM GW to the “Lync gateway” VCS allows traditional video codecs such as H.261, H.263 and H.264 to be converted to and from the Microsoft RT Video codec. Use of the RT Video codec allows a Lync client to scale its displayed image from CIF resolution, through VGA to 720p.
The Cisco AM GW enhances the video experience by upscaling the video format sent from Lync clients."
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Microsoft_Lync_and_Cisco_AM_GW_Deployment_Guide_X7-2.pdf
Anas
please rate if it is helpful
Dear Anas
It is not the same of course , because new microsoft LYNC 2013  uses h264 SVC codec  and this causes a problem with Cisco UC. Please advise .
Thank you
Islam kamal
Any suggestions please
Dear experts
can i get any help  please ?.
many thanks
Hi Islam,
I advise you to open a case with PDI helpdesk http://www.cisco.com/go/pdihelpdesk
they can help you or confirm my answer.
please share the answer to help the community
Anas
Marek Tarnoci
Hi Islam,
Do you have any solution for this issue? I have same problem.
Thanx
hello
Till now there is no update from Cisco side for integration with LYNC 2013  , so there is no result for these integration yet for polycom it works so fine and i saw this . I  have already contact Cisco engineers  and that what i have informed about , but integration works so well with LYNC2010 .
Thank you
please rate if this will help
Hi Islam
Thanks for your response. Yes I thought ... If you will have some new info, could you share an update please?
Thank you
Marek
cmcina2211
I was speaking with the cisco engineers and pre-sales staff and although the UC works with 2013 the click to call functionality does not and there is no road map to when the next version will be released and if it will fix this issue
