Cisco UCCX Subscriber Node Replication is not existing erro
amanullahkadiri
My UCS server was crashed. I rebuilt the server with my UCCX Subscriber node but after rebuilding i m getting error ( replication is not existing on this server).
In UCCX Publisher i have change security password and same password i have used in Subscriber Node.
5 Replies 5
vijit kumawat
1.From the CLI of publisher, run the command utils uccx syncusers.
2.From the CLI of subscriber, run the command utils uccx syncusers.
3.Deactivate subscriber config and historical datastores from the Serviceabilty page,if it is already activated.
4.Setup replication from the subscriber CLI by running the command "utils uccx dbreplication reset".
This can be run from the Serviceability -> DB Control Center page as well.
5.Activate subscriber config and historical datastores from the Serviceabilty page.
6.Wait for some time and check the status from the Serviceabilty->DB Control Center page.
7.Enable subscriber datastore components from the subscriber appadmin setup wizard if it not activated successfully.
8.Verify the replication status from the Serviceabilty->DB Control Center page.
https://supportforums.cisco.com/document/113931/uccx-replacing-crashed-node-85-issues
Thank you  Vijit Kumawat.
Aman, please rate if helpful and mark it correct answer if this solved your issue so others with the same issue can utilize the correct solution.
When i run the command on uccx publisher:
admin:utils uccx syncusers
Command failed.
Have  you logged in to the subscriber node and completed the initial wizard ?
