Cisco Unified Attendant Console - Requirements
dvaggalis
I am confused on a couple of issues with CUxAC, and conflicting  information between Datasheets, Install guides and this forum.
1.  Was CUxAC ever supported in a VM environment?
2.  Is the latest release 8.5 supported but only on a Cisco UCS server?
3.  Business and Department can be loaded on a desktop PC?  I don't see where this is documented, this forum points to the Datasheet, but I don;'t see where it specifically says the server software caon be loaed on a desktop, only the client.
Jaime Valencia
8.0(3) and above support virtualization.
Review this:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_%28including_OVA/OVF_Templates%29#Unified_Attendant_Consoles
No, you can use other HW and not UCS necessarily
You need separate HW for this, you cannot install server/client on the same machine.
Look at the OS requirements:
Cisco Unified Business Attendant Console Version  8.5.1
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_data_sheet0900aecd805e6a5f.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Java -
So can I run a CMBE 6000 on a C200 and then CUxAC on this as well?  or is only on the B series?
So far it's only supported on UCS B200 M1
Related info is here:
CSCtj21684
Cisco UCS virtualization is not supported
java
java
Thanks Java!
