Cisco Webex Assistant failed sign in attempts
Humza Khan
One of our client is using Cisco webex assistant, using it frequently but now getting this error.
Urgent help required.
HK
Edwin Matos
Easy, Logon to the web portal. If it auto login happens, make sure you click log off. After that you will need to login with the catcha, then you will be able to login as normal.
