CME:10.5 Incoming calls transferred through auto-attendant have no audio
Shahzad Ayub
We just upgraded the CME version from 9.1 to 10.5 and realized that we are having some issue with incoming calls which are transferred through auto attendant.Calling party does not hear any voice but called party can listen the calling party.
I am putting some configuration related to this issue and I have also attached log during the test call.
I called from 551540150 to 4207800(Auto attendant number) then I select 3 to transfer the call to HR(4207815), call transferred successfully but only called party can hear me and I cannot hear the called party.
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice translation-rule 1
 rule 1 /011420\(78..\)/ /\1/
 rule 2 /420\(78..\)/ /\1/
dial-peer voice 1 voip
 description ****INBOUND SIP CALL LEG*****
 translation-profile incoming incoming_calls
 session protocol sipv2
 session target sip-server
 incoming called-number 01142078..
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
Shahzad
Hi Carlo,
Thank you for your reply.
Please find the full config & debug ccsip in attachments.
Shahzad
10 Replies 10
Shahzad Ayub
everybody looks busy....... :(
Hi Experts,
Greetings
I am calling from IP Phone to PSTN & called party is not answering my call, after some rings call is getting hangup and i am not able to hear hangup tone or beep, rather i am getting system recording like "your call can not be completed as dialed please console your directory"
Please advise me to remove the system recording & let me able to get beep tone after called party not answering call
Thanks in advance
Warm Regards:
Nabeel Asghar
Hi Shahzad.
Your entire config and a debug ccsip message output could be useful
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Shahzad
Hi Shahzad
Under voice service voip and than sip
please add early-offer forced
and
midcall-signaling passthru
After these changes please post another output of debug ccsip message
Carlo
Hi Carlo,
I am unable to enter these commands as mentioned.
I would like to tell you, I have just upgraded CME version 9.0 to 10.5 and facing this issue.
Shahzad
Shahzad,
you have to add those command in this way
conf t
voice service voip
sip
early-offer forced
You can copy and paste on your terminal what above
Carlo
still same issue am attaching the log.
Shahzad
I just removed g711alaw codec under voice class codec and issue is resolved.
Shahzad
For the time-stamp I will assume it is solved, right?
I was about to mention a coded problem, but it seems you find it.
Regards.
Rolando Valenzuela.
