04-10-2018 09:10 AM - edited 03-17-2019 12:35 PM
I am having really strange results trying to test cbarge with CME 12.1 and 8800 phones. Some of what I am seeing
All phones have appearance of 101
Individual extensions
Phone A 401
Phone B 402
Phone C 403
plus there 2 FXO ports connect to another PBX
1. Place call from DN101 on phA out via FXO1 = Barge DN101 on phB successful
2. Receive call from FXO1 on phA DN101 = Barge DN101 from phB fails with fast busy
3. Receive call from FXO1 on phA, Confer DN402 into 101 call on phA, phC barge button changes from green background to greyed out - barge appears to be have been disable as if privacy enabled, returns to normal green status after dropping conference w/ DN402 (still fails to barge as scenario #2).
4. Place call from DN101 on phA out via FXO1 , Conference 2nd call by dialing out via FX02 on phA = Barge is lit greem on phB but fails with fast busy when pressed.
Some serious madness here. Anyone care to comment? yes have a TAC case open but haven't spoken to engineer in depth about this yet.
04-10-2018 10:15 PM
04-11-2018 10:06 AM
Are you hitting barge or cbarge softkeys?
Relevant key template info - cBarge is configured
"softkeys seized Cfwdall Endcall Redial
softkeys remote-in-use Newcall cBarge"
Are you limiting max lines per DN?
Have this configured for the shared DN
"shared-line max-calls 8"
On the Voice reg pool
"busy-trigger-per-button 8"
What codec being used during the call and is that codec add in CFB? show
call activ vo com
"ehpbx#show call active vo com
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp> VRF
Total call-legs: 2
3593 ANS T1 g711ulaw TELE P
3594 ORG T1 g711ulaw VOIP P101 192.168.10.5:29700 NA"
"dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
associate application SCCP"
Have you checked if your CFB registered to CME before barging? show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0/0
IPv4 Address: 192.168.10.1
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.10.1, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.10.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
04-11-2018 07:04 PM
