06-25-2013 11:58 AM - edited 03-16-2019 06:04 PM
Thanks.
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 300 min 60
midcall-signaling block
g729 annexb-all
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
sccp local GigabitEthernet0/1
sccp ccm 10.16.128.254 identifier 1 priority 1 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 4 register CFB2-FD
associate profile 2 register XCODE-FD
associate profile 1 register CFB-FD
associate profile 3 register MTP-FD
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 15
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
dspfarm profile 4 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 10
dspfarm profile 3 mtp
codec g729r8
maximum sessions software 200
voice register global
mode cme
source-address 10.16.128.254 port 5060
timeouts interdigit 2
max-dn 130
max-pool 130
load 7961 SIP41.9-3-1SR2-1S
load 3905 CP3905.9-2-2ES4
authenticate register
authenticate realm pna.com.br
timezone 17
time-format 24
date-format D/M/Y
hold-alert
dialplan-pattern 1 3092.... extension-length 4
tftp-path flash:
create profile sync 0004092474337402
network-locale U1
user-locale U1 load CME-locale-pt_BR-Portuguese-8.8.2.5.tar
ntp-server 10.16.128.254 mode directedbroadcast
conference hardware
telephony-service
sdspfarm units 4
sdspfarm tag 1 CFB-FD
sdspfarm tag 2 XCODE-FD
sdspfarm tag 3 MTP-FD
sdspfarm tag 4 CFB2-FD
conference hardware
no auto-reg-ephone
max-ephones 165
max-dn 500 no-reg
ip source-address 10.16.128.254 port 2000
system message CME Express 9.1
cnf-file location flash:
network-locale U1
load 7961 SCCP41.9-3-1SR2-1S
load 7961GE SCCP41.9-3-1SR2-1S
load 7965 SCCP45.9-3-1SR2-1S
load ata ATA030204SCCP090202A.zup
time-zone 17
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 3092.... extension-length 4 no-reg
max-conferences 8 gain -6
call-park system application
call-forward pattern .T
moh "flash:/music-on-hold.au"
web admin system name ommited
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp 7960 Jun 25 2013 14:53:58
voice register dn 1
number 7333
pickup-group 1
name TI-SND
label 7333
voice register pool 1
id mac XXXX.XXXX.XXXX
type 3905
number 1 dn 1
dialplan 1
dtmf-relay rtp-nte sip-notify
voice-class codec 1
username phone1 password cisco
ephone-dn 87 octo-line
number 7370 no-reg primary
label LJS
description 7370
ephone 87
mac-address XXXX.XXXX.XXXX
type 7961
button 1:87
06-25-2013 04:32 PM
Please look at:
Conference allows you to talk simultaneously with multiple parties. When you are talking on a call, use Conference to dial another party and add them to the call. You can remove individual participants from the conference if your phone supports the feature.
You can set up a conference by using the Hookflash feature on the phone. You can only include three participants in a conference. Use the hookflash feature to drop a participant from a conference. The conference ends when all the participants hang up.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
06-26-2013 04:55 AM
Thanks Jorge, but I think I was not very clear in my post. Or maybe you misread me. The 3905 work fine, the 7961 and 7965 don't.
I receive the message "Cannot Complete Conference". As you can see in my post above, I have the correct dspfarm profiles assigned and invoked. This is weird, so I opened a case with Cisco. Let's see what they can tell me, because I don't see anything wrong with my configs. I hope it is not a bug.
If it helps, I am using the latest firmware for the 7961 and 7965, both are 9.3.1
07-02-2013 05:37 PM
Hi aedamasceno
Were you able to fix the issue with the TAC Engineer?
Jorge Armijo
