CME & Asterisk SIP Trunk
ma7moud.geek1
Dear all,
I'm having a hard time registering  Asterisk server with CME i tried this configuration with no luck(Asterisk IP:10.1.1.81, Router IP: 10.1.1.10):
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
midcall-signaling passthru
sip-ua
credentials username gwadmin password 7 097F43080B11161606050A79 realm 10.1.1.10
keepalive target ipv4:10.1.1.10:5060
authentication username gwadmin password 7 063502205E5A081D081E1C58
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar ipv4:10.1.1.10:5060 expires 3600
sip-server ipv4:10.1.1.81:5060
host-registrar
dial-peer voice 13 voip
destination-pattern 6189500
session protocol sipv2
session target ipv4:10.1.1.81
dtmf-relay rtp-nte
codec g711alaw
on the Asterisk i did the following:
connections--> add trunk:
PEER Details
type=friend
context=incoming
host=10.1.1.10
disallow=all
allow=ulaw&alaw
nat=no
canreinvite=yes
qualify=yes
Register String:
gwadmin:Smartadmin3@10.1.1.10
Could please help me finding what is missing.
Thanks in advance.
gurbatullahk
Try this link     https://www.gkhan.in/how-to-configure-sip-trunk-between-cme-and-issabel/
type=friend
context=incoming      ------->  this is like partition in Cisco CME or call manager
host=10.1.1.10
disallow=all
allow=ulaw&alaw
nat=no
canreinvite=yes
qualify=yes
Register String:
gwadmin:Smartadmin3@10.1.1.10                  ---------->  if peer type is friend then register string not required
