07-29-2015 07:44 AM - edited 03-18-2019 11:35 AM
I am using dial-peers for my outbound calls to PSTN. A call to a 11 digits 0800 number is failing
dial-peer voice 10 pots
description ***Outbound to 10 Digit Free and Reduced Rate Calls
destination-pattern 908........
port 0/0/0:15
prefix 08
dial-peer voice 11 pots
description ***Outbound to 11 Digit Free and Reduced Rate Calls
destination-pattern 908.........
port 0/0/0:15
prefix 08
When an internal user dials 908003680638, the call fails.
Debug shows the digits as 0800368063
Seems to be hitting dial-peer 10 not dial-peer 11
Interdigits are set to 7
voice register global
timeouts interdigit 7
As a work around I have added another dial-peer
dial-peer voice 12 pots
description ***Outbound to 11 Digit to Conference
destination-pattern 90800368063
port 0/0/0:15
prefix 08003680638
Now debug shows 08003680638 and call completes
Any ideas
Steve
07-29-2015 07:56 AM
Use $
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/15-mt/vd-15-mt-book/vd-dp-feat-cfg.html
07-29-2015 08:18 AM
I removed my work around dial-peer voice 12 pots
Added the $ to the end of the destination patterns, still the same issue
destination-pattern 908........$
port 0/0/0:15
prefix 08
destination-pattern 908.........$
port 0/0/0:15
prefix 08
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839C
Exclusive, Channel 28
Calling Party Number i = 0x0181, '1628641000'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0800368063'
07-29-2015 08:51 AM
I have deleted both dial-peers and added them back in reverse order. Seems to be ok now, weirdly..
port 0/0/0:15
prefix 08
port 0/0/0:15
prefix 08
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, '08003680638'
