CME not register to ITSP
fernandogarciat
Hi guys.
I'm trying to register a cme to a trunk sip server but I get some error messages, the funny thing is that when I try to register a SIP cliente in my PC like a x-lite cliente, with the same parameters, it registers and I'm able to make calls.
Here are some loggs a got from cme.
*Jan 12 19:06:10.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:x.x.x.x:5060 SIP/2.0
Via: SIP/2.0/UDP 150.4.4.113:5060;branch=z9hG4bK713D0
To: <sip:2221416171@x.x.x.x>
Date: Mon, 12 Jan 2015 19:06:10 GMT
Call-ID: 7C3D6A83-99C411E4-8022A211-664AD4BD
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1421089570
CSeq: 5 REGISTER
Contact: <sip:2221416171@150.4.4.113:5060>
Expires: 3600
Authorization: Digest username="2221416171",realm="alestrapue.com",uri="sip:x.x.x.x:5060",response="5752665c129dac1a2dc5bf65f9b21ad4",nonce="BroadWorksXi4u7vtnrTlwmrwbBW",cnonce="A60DA373",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
*Jan 12 19:06:10.799: //115/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 150.4.4.113:5060;received=201.139.100.90;branch=z9hG4bK713D0;rport=54162
To: <sip:2221416171@x.x.x.x>;tag=1441184958-1421089310494
CSeq: 5 REGISTER
WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXi4u7vtpaTi01nhoBW",realm="alestrapue.com",algorithm=MD5
Content-Length: 0
*Jan 12 19:06:10.803: //115/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
R1(config-sip-ua)# host-registrar
*Jan 12 19:06:10.803: //115/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
*Jan 12 19:06:50.275: //116/000000000000/SIP/Error/sipSPIAddPrivacyHeader: Orig Container is NULL...should have value
*Jan 12 19:06:50.275: //116/000000000000/SIP/Error/sipSPIAddAssertedIDHeader: Orig Container is NULL...should have value
*Jan 12 19:06:50.275: //116/000000000000/SIP/Error/sipSPIAddPreferredIDHeader: Orig Container is NULL...should have value
*Jan 12 19:06:50.275: //116/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:x.x.x.x:5060 SIP/2.0
Via: SIP/2.0/UDP 150.4.4.113:5060;branch=z9hG4bK721B2E
To: <sip:x.x.x.x>
Date: Mon, 12 Jan 2015 19:06:50 GMT
Call-ID: FF3C9268-99C411E4-8024A211-664AD4BD@150.4.4.113
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:150.4.4.113:5060>
Content-Length: 0
*Jan 12 19:06:50.355: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length: Could not get Content-length
*Jan 12 19:06:50.355: //116/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
R1(config-sip-ua)# host-registrarSIP/2.0 405 Method Not Allowed
Via: SIP/2.0/UDP 150.4.4.113:5060;received=201.139.100.90;branch=z9hG4bK721B2E;rport=54162
To: <sip:x.x.x.x>;tag=aprqngfrt-uup31020000a6
CSeq: 101 OPTIONS
Allow: INVITE,ACK,BYE,REGISTER,CANCEL,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,UPDATE
0 Replies 0
