CME separate tftp servers for configuration & firmware
Dimitris Mingos
Is it possible to have two different tftp servers in my network?
1st tftp-server for IP Phones configuration files
2nd tftp-serverfor IP Phone firmware loads
Thank you
Dimitris
Harmit Singh
Hi Dimitris,
Not sure what the objective of doing this is, but this is ideally not possible. The phone will talk to the same TFTP for getting both its config file as well as phone firmware i.e. option 150 in your DHCP server.
Harmit.
Hello Harmit,
Thank you for your replay.
I have a site-to-site VPN connections and IP Phone firmeware upgrade is very slow.
I found a solution a while ago using double tftp server option in my Voice DHCP.
Dimitris
Glad to hear that Dimitris! :-)
Harmit.
