05-20-2019 12:49 PM
I am using a Cisco 9971 IP phone with CME UC540W Version 12.4(24r)SB and trying to get to the "phone services" menu inside the phone. The problem is that whenever I click the "phone services" button in the settings menu, the only option that appears is "Afterhour Login" to which I click, and enter every possible pin I have or know of, and nothing gets through.
I am looking for a way to either:
It is worth noting, I tried doing this as 1:00 PM, the middle of the day, so I have no idea how it thinks it is "after hours"
Below is the relevant config.
Thanks in advance for any assistance!
voice service voip
ip address trusted list
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 600 min 60
no update-callerid
sip-profiles 1000
voice register global
mode cme
source-address 10.1.1.1 port 5060
no outbound-proxy
max-dn 56
max-pool 14
load 9971 phones/9971/sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
authenticate register
timezone 12
hold-alert
voicemail 3099
url directory http://10.1.1.1/localdirectory
tftp-path flash:
create profile sync 2184221155512747
voice register dn 1
translation-profile incoming SIP_Passthrough
number 8041
call-forward b2bua busy 3099
call-forward b2bua noan 3099 timeout 20
call-forward b2bua unregistered 3099
name John Doe
label John Doe
voice register pool 1
id mac DCA5.F486.1234
feature-button 6 DnD
feature-button 12 Cfwdall
session-transport tcp
type 9971
number 1 dn 1
dtmf-relay rtp-nte
username JDoe password 123456
codec g711ulaw
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Some Company
cnf-file location flash:
cnf-file perphone
load 7937 apps37sccp.1-4-4-0
load 521G-524G cp524g-8-1-17
time-zone 12
keepalive 30 auxiliary 4
voicemail 3099
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6.... blind
secondary-dialtone 9
after-hours override-code 1234 # < Added this later, made no difference
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
05-23-2019 01:10 PM
Looking at this, still unable to find any reason why this should work. Any ideas?
