CME tcl script file.
kingvoice
Dear Experts !
                      I have  cisco CME router and i would like to configue Auto Attendant by using TCL script file . Can any one provide me the
sample configuration and default TCL scirpt files .
Regards;
KV
33 Replies 33
as I told you, remove hunt0 from your configuration and add param operator 3015
please rate all helpful posts
Cao
Please rate all helpful posts "The more you help the more you learn"
Done but no luck...Thanks for your replies.
Hi.
After you change any parameter to the application , you have to restart it.
Show call application sessio
is the command to discover the session id
Locate the hexadecimal id and than
call application session stop id xxxx
after that try to call again
Please post your actual configuration
Carlo
Please find the attached configuration.
did you restart the application as I mentioned?
Please activate a debug voip application script , call the application and send me the output..
Let me know
Carlo
Below is the output ;
Oct 15 12:03:09.567: //368//TCL :/tcl_PutsObjCmd:
proc init_perCallvars
Oct 15 12:03:09.567: //368//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:03:09.567: //368//TCL :/tcl_PutsObjCmd: is mlpp = 0
>>>>>>>>>legstate = lg_001<<<<<<<<<<<
Oct 15 12:03:09.567: //368//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcome Prompt and options menu ++
VGW#
Oct 15 12:03:25.322: //3//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
VGW#
Oct 15 12:03:28.358: //368//TCL :/tcl_PutsObjCmd: >>>>>>>>>>>>> return from infotag get evt_dcdigits is : 0 <<<<<<<<<<<<<<<<<<<<<<<<<
Oct 15 12:03:28.358: //368//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:03:28.358: //368//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Oct 15 12:03:28.358: TCL script failure
        Result:
                         Play Failed
Oct 15 12:03:28.358:    TCL script failure errorInfo:
                        Play Failed
    while executing
"media play leg_incoming moh:livemoh"
    (procedure "act_GotDestNoOption" line 49)
    invoked from within
    ("0" arm line 2)
    invoked from within
"switch -exact $optionSelected {
                                        act_RetryMenu
                                {0} {
                                        act_GotDestNoOption
                                default {
                                        set playMusicFlag 1
    (procedure "act_GotDest" line 38)
    invoked from within
"act_GotDest"
Oct 15 12:03:28.358: //3//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ New incoming call to queue 3011 +++
Oct 15 12:03:28.358: //3//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Queue index is 0 <<<
VGW#TCL B-ACD:  >>> THE QUEUE NOW IS {TclModule_23A638C_0_108870232 {CALL_NEW} {1444910608} {0}} <<<
Oct 15 12:03:28.358: //3//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ 3011 Queue Length = 1 +++
Oct 15 12:03:28.358: //3//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS  <<<
Hi.
It seems that you aren't following my instructions.
on telephony-service
moh flash:moh.au (or whatever) you need to specify absolute path
Than you need to terminate all active sessions before testing again.
Now please correct the moh config, write the config into nvram and reload the gateway.
Once the gateway back online, test again an let me know.
Carlo
Hi Carlo ;
             I am doing the same step as per  your advice, let correct the Moh file path ,
also tell me is there anyway that i can reach directly to the extension
we want to dial direct extension during greeting ,no dial by option number,
Hi.
Now I see that the call is going to extension 3011 but 3011 is unavailable.
If you want to be able to reach a destination by dialing the extension, you need dial-by-extension option that you already have as option 1 but option 1 is not available because  already assigned to an hunt destination.
If you tell what's your final desired layout of this IVR ,
I can write you the final working config ;-)
Please let me know
Carlo
Thanks ;
           I can reach to extension by pressing 1 .. then extension number 4XXX
what  i need like this ;
welcome msg " PLease dial the required extension or zero for operator "
NO need to  PRESS one then extension..
Hi.
In this case you will need only its-Cisco.x.x.tcl
That script allows you to enter a destination without making any selection.
Please download it and make a new application.
application
service CSC flash: its-CISCO.2.0.2.0.tcl
  paramspace english language en
  paramspace english index 1
  paramspace english location flash:
  paramspace english prefix en
  param aa-pilot 900
  param operator 6446
Try it and let me know
Carlo
I had the same problem, in my case the problem was the moh audio file.
Reviews the audio file format and check the telephony service command.
telephony-service
 moh enable-g711 "flash0:en_bacd_music_on_hold.au"
John  Wallace
Hi.
Did you have any chance to try the suggested config?
Please let me know
Carlo
Now the music on hold file is working but still zero is not working
VGW#
Oct 15 12:48:44.309: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
VGW#
Oct 15 12:48:46.709: //400//TCL :/tcl_PutsObjCmd:
Oct 15 12:48:46.709: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:48:46.709: //400//TCL :/tcl_PutsObjCmd: is mlpp = 0
Oct 15 12:48:46.709: //400//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcome Prompt and options menu ++
VGW#
Oct 15 12:48:53.645: //400//TCL :/tcl_PutsObjCmd: >>>>>>>>>>>>> return from infotag get evt_dcdigits is : 0 <<<<<<<<<<<<<<<<<<<<<<<<<
Oct 15 12:48:53.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:48:53.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ New incoming call to queue 3011 +++
Oct 15 12:48:53.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Queue index is 0 <<<
Oct 15 12:48:53.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE NOW IS {TclModule_23A60AC_0_111607404 {CALL_NEW} {1444913333} {0}} <<<
VGW#TCL B-ACD: +++ 3011 Queue Length = 1 +++
Oct 15 12:48:53.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 0 ,return value: 0
Oct 15 12:48:53.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 1 ,return value: -1
Oct 15 12:48:53.645: //400//TCL :/tcl_PutsObjCmd: TCL AA: >>> Destination Huntgroup = 3011 <<<
Oct 15 12:48:53.649:
Oct 15 12:48:53.649: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913333} {0}} <<<
VGW#
Oct 15 12:49:03.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:03.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913343} {0}} <<<
Oct 15 12:49:03.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
VGW#
Oct 15 12:49:13.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:13.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913353} {0}} <<<
Oct 15 12:49:13.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
VGW#
Oct 15 12:49:23.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:23.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913363} {0}} <<<
Oct 15 12:49:23.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
VGW#
VGW#
VGW#
Oct 15 12:49:33.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:33.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913373} {0}} <<<
Oct 15 12:49:33.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
VGW#
Oct 15 12:49:43.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:43.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913383} {0}} <<<
Oct 15 12:49:43.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
Oct 15 12:49:44.309: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
Oct 15 12:49:44.309: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913383} {0}} <<<
VGW#TCL B-ACD: >>> {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913383} {0}} <<<
VGW#
Oct 15 12:49:53.645: //400//TCL :/tcl_PutsObjCmd: TCL AA: +++ COLLECTING DIGITS TO QUIT QUEUE +++
Oct 15 12:49:53.645: //400//TCL :/tcl_PutsObjCmd: TCL AA: +++ Now playing second greeting prompt +++
Oct 15 12:49:53.645: //400//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Oct 15 12:49:53.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_23A60AC_0_111607404 {CALL_PROGRESS} {1444913393} {0}} <<<
Oct 15 12:49:53.645: //382//TCL :/tcl_PutsObjCmd: TCL B-ACD: >>> Received HELLO from TclModule_23A60AC_0_111607404 <<<
@Carlo Poggiarelli
Could you help me why it always gives me "1 Call in queue" and if the phone not answers is always ringing and the Handset flashes, which I don't want to happen!
Any help please
