05-19-2015 09:04 AM - edited 03-18-2019 11:31 AM
Looking for compatible headset for 8945/9951 and 9971 phones.
is the headset in the following link compatible?
http://www.plantronics.com/us/product/tristar?skuId=sku550016#accessories
end user does not want to use Bluetooth.
Thank you in advance for your assistance.
Solved! Go to Solution.
05-19-2015 09:16 AM
Looks like it's compatible based on other sites:
http://www.headsetexperts.com/compatibility/phones/cisco-8945.html
Jabra also makes some quality headsets:
http://www.jabra.com/sa/cisco/headsets/Cisco_8945?gclid=CI3S5o2azsUCFRQcaQodKTQApw
05-19-2015 09:16 AM
05-19-2015 09:24 AM
Thank you for the quick reply Brandon.
I believe Jabra is the way to go.
(+5)
