01-11-2010 11:35 PM - edited 03-15-2019 09:02 PM
i have a CCM 5.1.3, and i want to do some configuration for the operator number, where 2 receptionests will be handling calls coming to this number.
so is there a way to do this ??
any help or useful refreneces will be great
thanks in advance
Solved! Go to Solution.
01-13-2010 02:16 AM
each one will use his own number
and the main number you assign it to the hunt pilot number
create first line group then hunt list then the hunt pilot
all the required configurations you can find it in the bellow link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b03lngrp.html
good luck
if helpful Rate
01-12-2010 03:59 AM
do you want their phones to ring together or first one ring
and the second call will ring the second receptionist if the first one busy
both of the above can be done by using hunt group and hunt list
create a line group put the lines of the receptionists under it ( make it broadcast if you want both phones to ring together)
create hunt list and chose the line group above
then create hunt pilot with the and put the number as the number people will dial it
good luck
if helpful Rate
01-13-2010 02:05 AM
thanks for your reply
i will try to do it, but can you please provide some references for this kind of config. ?
and do i need to assign them the same ext. number ?? or each one should have his own extension ??
Best regards
Omar
01-13-2010 02:16 AM
good luck
if helpful Rate
01-24-2010 12:58 AM
Hey marwan,
It worked perfectley, thanks alot for this.
but i have a question, now for the regular phone with ana extension i can specify how many line it can take simultenousley, so it can be up to 6.
now with these extensions that is part of this line group, i configured each one to take 2 lines at the same time but it is not doing this, each extension can take only one line.
do you have any idea about this ?? does it need any other configs or it is just like this ?
01-24-2010 01:14 AM
you mean you want to recieve more than a call at the same timeon each DN ?
if yes try to increase the busy triger number in the Line (DN) seeting page yiou will find this option in the end of the line seeting page
good luck
if helpful Rate
