Configuring COR / COS on VIC3-2E/M in a 2911 Router - IPICS system
jgatschuff
I have a radio connected to a VIC3-2E/M card in a 2911 router. Originally it was configured as VAD and worked properly (see voice-port 0/2/0 below for config).  We are trying to re-configure to use COR/COS (m-lead ) signaling. Unfortunately it is not working.  Keypad tones on the radio are still triggering the IPICS system which seems to indicate the router is not monitoring / following the state of the m-lead. See voice-port 0/2/1 for the m-lead configuration.
The radio can be configured to use either active high (+5V) or active low to indicate an incoming signal.  It is currently configured for active high signaling.  The LMR connection is wired as below.  I have verified the signaling on Pin 2 of the LMR plug.  It is responding properly,  it is 0.5V on standby, 4.8V when receiving a signal and when keypad tones are generated the line remains low.
I am looking for thought on how to configure the router for m-lead signaling to work properly.
 Radio                                           VIC3 2E/M Jack
                                                          Pin 1
COR/COS  ---------------------- Pin 2
Pwr Gnd    ---------------------- Pin 3
Rx Audio    ---------------------- Pin 4
Tx Audio    ---------------------- Pin 5
Audio Gnd ---------------------- Pin 6
PTT           ---------------------- Pin 7
GND          ---------------------- Pin 8
Router Config
Current configuration : 7246 bytes
version 15.4
hostname D23DCRRT02
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.154-2.T4.bin
boot-end-marker
no aaa new-model
ip domain name xxx.com
ip multicast-routing
ip cef
no ipv6 cef
voice-card 0
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 ilbc
voice class permanent 1
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
hw-module pvdm 0/0
redundancy
interface Loopback0
ip address zzz.yyy.254.13 255.255.255.255
ip pim sparse-mode
ip igmp join-group xxx.1.1.1
interface Tunnel500
ip address www.yy2.1.2 255.255.255.248
ip pim sparse-mode
tunnel source zzz.yy1.15.30
tunnel destination zzz.yy1.15.29
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address zzz.yy1.15.26 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
ip address zzz.yy1.15.30 255.255.255.252
ip ospf cost 1000
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Async0/0/0
no ip address
encapsulation slip
interface Async0/0/1
no ip address
encapsulation slip
interface Async0/0/2
no ip address
encapsulation slip
interface Async0/0/3
no ip address
encapsulation slip
interface Async0/0/4
no ip address
encapsulation slip
interface Async0/0/5
no ip address
encapsulation slip
interface Async0/0/6
no ip address
encapsulation slip
interface Async0/0/7
no ip address
encapsulation slip
interface Vif1
ip address zzz.yy1.15.70 255.255.255.252
ip pim sparse-mode
router ospf 4
area 52 nssa
network zzz.yy1.15.70 0.0.0.0 area 52
network zzz.yyy.254.13 0.0.0.0 area 52
network www.yy2.1.2 0.0.0.0 area 52
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address zzz.yyy.254.1
logging source-interface Loopback0
logging host vvv.uuu.25.189
control-plane
voice-port 0/1/0
auto-cut-through
voice-class permanent 1
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
output attenuation 17
no echo-cancel enable
no comfort-noise
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-in 10
timing hangover 40
timing delay-voice tdm 250
connection trunk 192111
description VAD Radio Maint:Airside Electrical
threshold noise -40
voice-port 0/1/1
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 192112
description VAD Radio Maint:Baggage
threshold noise -40
voice-port 0/2/0
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 192113
description VAD Radio Maint:Janitorial
threshold noise -40
voice-port 0/2/1
operation 4-wire
signal lmr
bootup e-lead off
lmr m-lead audio-gate-in
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 192114
description VAD Radio Tech Support
threshold noise -40
voice-port 0/3/0
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 192115
description VAD Radio Terminal Mechanical
threshold noise -40
voice-port 0/3/1
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr duplex half
lmr led-on
input gain 16
no comfort-noise
timing hangover 40
connection trunk 192116
description VAD Radio Security Operations
threshold noise -40
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 192111 voip
destination-pattern 192111
rtp payload-type lmr-tone 107
rtp payload-type nte-tone 108
session protocol multicast
session target ipv4:xxx.192.1.11:22022
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
vad aggressive
dial-peer voice 192112 voip
destination-pattern 192112
session target ipv4:xxx.192.1.12:22024
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
dial-peer voice 192113 voip
destination-pattern 192113
session target ipv4:xxx.192.1.13:22026
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
dial-peer voice 192114 voip
destination-pattern 192114
session target ipv4:xxx.192.1.14:22028
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
dial-peer voice 192115 voip
destination-pattern 192115
session target ipv4:xxx.192.1.15:22030
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
dial-peer voice 192116 voip
destination-pattern 192116
session target ipv4:xxx.192.1.16:22032
dtmf-relay rtp-nte
codec g711ulaw
vad aggressive
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0 0/0/7
line vty 0 4
login local
transport input all
transport output all
scheduler allocate 20000 1000
end
D23DCRRT02#
0 Replies 0
