09-01-2020 04:45 AM
we had to move our CME from public IP behind NAT, so our ISTP changed configuration for our SIP trunk to register with authentication. Now I have LoginID, AuthID and Password that I have added to the configuration. The problem is that I can still call between our internal phones, but incoming and outgoing calls are not working.
This is the current configuration:
version 15.1 service timestamps debug datetime msec localtime service timestamps log datetime msec localtime no service password-encryption ! hostname voip_router ! boot-start-marker boot-end-marker ! ! logging buffered 64000 no logging console ! no aaa new-model clock timezone CET 1 0 clock summer-time METDST recurring last Sun Mar 2:00 last Sun Oct 3:00 ! no ipv6 cef no ip source-route ip cef ! ! ip dhcp pool POOL1 import all network 192.168.20.0 255.255.255.0 option 150 ip 192.168.20.1 default-router 192.168.20.254 dns-server 192.168.20.254 lease 7 ! ip dhcp pool POOL2 import all network 10.20.52.0 255.255.255.0 option 150 ip 10.20.52.1 default-router 10.20.52.1 dns-server 10.20.52.1 lease 7 ! ! ip domain name nsppeer.sipserver.cz ip name-server 192.168.2.100 multilink bundle-name authenticated ! ! ! ! ! crypto pki token default removal timeout 0 ! crypto pki trustpoint TP-self-signed-1508924877 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-1508924877 revocation-check none rsakeypair TP-self-signed-1508924877 ! ! voice-card 0 dsp services dspfarm ! ! ! voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip no supplementary-service sip moved-temporarily no supplementary-service sip refer no supplementary-service sip handle-replaces fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip registrar server ! voice class codec 1 codec preference 1 g711alaw codec preference 2 g711ulaw ! ! voice register global mode cme source-address 10.20.52.1 port 5060 max-dn 100 max-pool 50 authenticate register authenticate realm gi.local tftp-path flash: create profile sync 0048234055148343 ! ! voice translation-rule 1 rule 1 /^5880083\(..\)/ /\1/ ! voice translation-rule 2 rule 1 /^9\(.*\)/ /\1/ ! voice translation-rule 3 rule 1 /^\(..\)$/ /5880083\1/ ! voice translation-rule 4 rule 1 /^\(.*\)/ /9\1/ ! ! voice translation-profile IN translate calling 4 translate called 1 ! voice translation-profile OUT translate calling 3 translate called 2 ! ! ! ! ! redundancy ! ! ! ! ! interface Loopback0 ip address 85.160.71.87 255.0.0.0 ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 description LAN$ETH-LAN$ no ip address ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/0.20 encapsulation dot1Q 20 ip address 192.168.20.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface GigabitEthernet0/1 description WAN$ETH-LAN$ ip address 192.168.2.1 255.255.255.0 ip nat outside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/2 description $ES_LAN$ no ip address duplex auto speed auto ! interface GigabitEthernet0/2.10 encapsulation dot1Q 10 ip address 10.20.51.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface GigabitEthernet0/2.20 encapsulation dot1Q 20 ip address 10.20.52.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! ip forward-protocol nd ! ip http server ip http authentication local ip http secure-server ip http path /gui ! ip nat inside source list 20 interface GigabitEthernet0/1 overload ip route 0.0.0.0 0.0.0.0 192.168.2.100 ip route 192.168.110.0 255.255.255.0 192.168.20.254 ! access-list 20 permit 192.168.20.0 0.0.0.255 access-list 103 permit ip host 192.168.2.100 any access-list 103 permit ip host 195.122.201.48 any access-list 103 permit ip host 195.122.207.102 any ! ! tftp-server flash:SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn tftp-server flash:DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn tftp-server flash:spa50x-30x-7-5-4.bin alias spa50x-30x-7-5-4.bin tftp-server flash:spa525g-7-5-4.bin alias spa525g-7-5-4.bin tftp-server flash:spa525g-7-5-4-bt.bin alias spa525g-7-5-4-bt.bin tftp-server flash:SCCP69xx.9-4-1-3SR2.zz.sgn alias SCCP69xx.9-4-1-3SR2.zz.sgn tftp-server flash:DSP69xx.12-4-122-99.131025.zz.sgn alias DSP69xx.12-4-122-99.131025.zz.sgn ! control-plane ! call threshold global cpu-avg low 68 high 75 call threshold global total-mem low 75 high 85 call threshold global total-calls low 8 high 10 ! ! ! mgcp profile default ! ! dial-peer voice 1 voip translation-profile incoming IN session protocol sipv2 session target dns:sip.sipserver.cz incoming called-number .% no voice-class sip tel-config to-hdr dtmf-relay rtp-nte codec g711alaw no vad authentication username AuthID password Password realm xxx.net ! dial-peer voice 2 voip description "Outgoing ... " translation-profile outgoing OUT destination-pattern 9T session protocol sipv2 session target dns:sip.sipserver.cz dtmf-relay sip-notify rtp-nte codec g711alaw no vad authentication username AuthID password Password realm xxx.net ! ! presence ! gateway timer receive-rtp 1200 ! sip-ua credentials number LoginID username AuthID password Password realm xxx.net keepalive target dns:sip.sipserver.cz authentication username AuthId password Password realm xxx.net timers connect 100 sip-server dns:sip.sipserver.cz registrar dns:sip.sipserver.cz expires 3600 ! ! ! gatekeeper shutdown ! ! telephony-service no auto-reg-ephone max-ephones 50 max-dn 100 ip source-address 10.20.52.1 port 2000 max-redirect 5 timeouts interdigit 5 timeouts busy 5 cnf-file location flash: load 6921 SCCP69xx.9-1-1-0.loads load 6941 SCCP69xx.9-1-1-0.loads load 6961 SCCP69xx.9-1-1-0.loads time-format 24 date-format dd-mm-yy dialplan-pattern 1 5880083.. extension-length 2 extension-pattern .. max-conferences 8 gain -6 call-forward pattern .T web admin system name root secret 5 $1$y9FH$E3BthLUA0.EQ061FnAzNB. dn-webedit time-webedit transfer-system full-consult transfer-pattern .T create cnf-files version-stamp 7960 Nov 19 2018 05:39:34 ! ! ! ! line con 0 line aux 0 line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 login local transport input telnet ssh ! scheduler allocate 20000 1000 ntp server 194.160.23.2 end
I would be very grateful for any help.
09-01-2020 07:54 AM
Hi Lukas,
Under Voice Service voip -->sip
add:
bind all source-interface GigabitEthernet0/2.20
Activate a debug ccsip messages , make a call and capture the output.
Please post the result of the debug output here
Thanks a lot
Best Regards
Carlo
09-01-2020 11:48 PM - edited 09-02-2020 01:31 AM
Hi Carlo,
thank you for your answer.
In the meantime, the registration the the ISTP is now working so that we can make outgoing calls. Now there are two main problems, that we need to solve:
1. Our phones are registering twice - one for our CME is OK, but now they are registering even to the ISTP. I have tryied solutions, that I found (no-reg both, restarting CME, terstarting phones), but with no luck.
Edit: This twice registration remains only for SCCP phones - the SIP phones are OK and CME is not sending their registration to the ITSP. Example of this second registration to the ITSP:
Sep 2 09:30:53.058: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.sipserver.cz:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.1:5060;branch=z9hG4bKA5310B7
From: <sip:588008321@sip.sipserver.cz>;tag=3B976F8-BFA
To: <sip:588008321@sip.sipserver.cz>
Date: Wed, 02 Sep 2020 07:30:53 GMT
Call-ID: 9DAC1480-EC1211EA-88BA9098-170B4059
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1599031853
CSeq: 46 REGISTER
Contact: <sip:588008321@192.168.2.1:5060>
Expires: 3600
Supported: path
Content-Length: 0
2. Incoming calls are not working - our CME is replying with 403 Forbidden, see this messages log:
Sep 2 07:22:38.657: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:588008311@192.168.2.1:5060;transport=udp SIP/2.0 Call-ID: 29963-NF-31dfeb52-7b6d017e5@sip.sipserver.cz Contact: <sip:195.122.207.107:5060> Content-Type: application/sdp CSeq: 600327315 INVITE From: "777028067" <sip:777028067@sip.sipserver.cz;user=phone>;tag=29963-IZ-31dfeb53-14e0eda00 Max-Forwards: 28 Record-Route: <sip:195.122.207.107:5060;lr>;session=47906 To: <sip:588008320@195.122.207.107:5060;user=phone> Via: SIP/2.0/UDP 195.122.207.107:5060;branch=z9hG4bK-NHXT-c3c72b69-067e85a6 Allow: INVITE,ACK,BYE,CANCEL,OPTIONS,SUBSCRIBE,NOTIFY,UPDATE,REFER,REGISTER,INFO User-Agent: Cirpack/v4.88 (gw_sip) Content-Length: 334 v=0 o=anonymous 159902743669 159902743669 IN IP4 195.122.207.107 s=SIP Call c=IN IP4 195.122.201.50 t=0 0 m=audio 32656 RTP/AVP 8 18 101 b=AS:82 a=rtpmap:8 PCMA/8000/1 a=rtpmap:18 G729/8000/1 a=fmtp:18 annexb=no a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=ptime:20 a=sendrecv a=sqn:0 a=cdsc: 1 image udptl t38 Sep 2 07:22:38.665: //4086/26BC1F2D88D8/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 100 Trying Via: SIP/2.0/UDP 195.122.207.107:5060;branch=z9hG4bK-NHXT-c3c72b69-067e85a6 From: "777028067" <sip:777028067@sip.sipserver.cz;user=phone>;tag=29963-IZ-31dfeb53-14e0eda00 To: <sip:588008320@195.122.207.107:5060;user=phone> Date: Wed, 02 Sep 2020 05:22:38 GMT Call-ID: 29963-NF-31dfeb52-7b6d017e5@sip.sipserver.cz CSeq: 600327315 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-12.x Content-Length: 0 Sep 2 07:22:38.665: //4086/26BC1F2D88D8/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 403 Forbidden Via: SIP/2.0/UDP 195.122.207.107:5060;branch=z9hG4bK-NHXT-c3c72b69-067e85a6 From: "777028067" <sip:777028067@sip.sipserver.cz;user=phone>;tag=29963-IZ-31dfeb53-14e0eda00 To: <sip:588008320@195.122.207.107:5060;user=phone>;tag=3440EE4-1C18 Date: Wed, 02 Sep 2020 05:22:38 GMT Call-ID: 29963-NF-31dfeb52-7b6d017e5@sip.sipserver.cz CSeq: 600327315 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-12.x Reason: Q.850;cause=21 Content-Length: 0 Sep 2 07:22:38.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: ACK sip:588008311@192.168.2.1:5060;transport=udp SIP/2.0 Call-ID: 29963-NF-31dfeb52-7b6d017e5@sip.sipserver.cz CSeq: 600327315 ACK From: "777028067" <sip:777028067@sip.sipserver.cz;user=phone>;tag=29963-IZ-31dfeb53-14e0eda00 Max-Forwards: 28 To: <sip:588008320@195.122.207.107:5060;user=phone>;tag=3440EE4-1C18 Via: SIP/2.0/UDP 195.122.207.107:5060;branch=z9hG4bK-NHXT-c3c72b69-067e85a6 Content-Length: 0
Hera is part of our current config:
voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip no supplementary-service sip moved-temporarily no supplementary-service sip refer no supplementary-service sip handle-replaces fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip registrar server ! voice register global mode cme source-address 10.20.52.1 port 5060 no outbound-proxy max-dn 100 max-pool 50 authenticate register authenticate realm gi.local tftp-path flash: create profile sync 0048234055148346 ! voice register dn 8 number 60 name Rozvodna 11,5 kV no-reg label Rozvodna 11,5 kV ! voice register dn 9 number 88 name xlitetest no-reg label xlite ! voice register dn 10 number 40 name Rozvodna 400 V no-reg label Rozvodna 400 V ! voice register dn 11 number 00 name Velin no-reg label Velin ! voice register dn 12 number 41 name Udrzba no-reg label Udrzba ! voice register dn 13 number 42 name Datova rozvodna no-reg label Datova rozvodna ! voice register dn 14 number 61 name Rozvodna 110 kV no-reg label Rozvodna 110 kV ! voice register dn 15 number 43 name Zasedacka no-reg label Zasedacka ! voice register pool 1 id mac 3CCE.73D2.BF6A number 1 dn 8 dtmf-relay sip-notify username rozvodna115kV password rozvodna115kV codec g711alaw ! voice register pool 2 id mac DEAD.BEEF.0001 number 2 dn 9 dtmf-relay sip-notify username xlsip password xlsip codec g711ulaw ! voice register pool 3 id mac 3CCE.73D2.BEE8 number 3 dn 10 dtmf-relay sip-notify username rozvodna400V password rozvodna400V codec g711alaw ! voice register pool 4 id mac 7081.05B3.B500 number 4 dn 11 username velin password velin codec g711alaw ! voice register pool 5 id mac 7081.05B3.B5A6 number 5 dn 12 username udrzba password udrzba codec g711alaw ! voice register pool 6 id mac 3CCE.73D2.BEE7 number 6 dn 13 username datroz password datroz codec g711alaw ! voice register pool 7 id mac 3CCE.73D2.BF0A number 7 dn 14 dtmf-relay sip-notify username rozvodna110kV password rozvodna110kV codec g711alaw ! voice register pool 8 id mac 7C2F.80B9.B030 number 8 dn 15 dtmf-relay sip-notify username zasedacka password zasedacka codec g711alaw ! ! ! voice translation-rule 1 rule 1 /^5880083\(..\)/ /\1/ ! voice translation-rule 2 rule 1 /^9\(.*\)/ /\1/ ! voice translation-rule 3 rule 1 /^\(..\)$/ /5880083\1/ ! voice translation-rule 4 rule 1 /^\(.*\)/ /9\1/ ! ! voice translation-profile IN translate calling 4 translate called 1 ! voice translation-profile OUT translate calling 3 translate called 2 ! interface Loopback0 ip address 85.160.71.87 255.0.0.0 ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 description LAN$ETH-LAN$ no ip address ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/0.20 encapsulation dot1Q 20 ip address 192.168.20.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface GigabitEthernet0/1 description WAN$ETH-LAN$ ip address 192.168.2.1 255.255.255.0 ip nat outside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/2 description $ES_LAN$ no ip address duplex auto speed auto ! interface GigabitEthernet0/2.10 encapsulation dot1Q 10 ip address 10.20.51.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface GigabitEthernet0/2.20 encapsulation dot1Q 20 ip address 10.20.52.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! ip forward-protocol nd ! ip http server ip http authentication local ip http secure-server ip http path /gui ! ip nat inside source list 20 interface GigabitEthernet0/1 overload ip route 0.0.0.0 0.0.0.0 192.168.2.100 ip route 192.168.110.0 255.255.255.0 192.168.20.254 ! access-list 20 permit 192.168.20.0 0.0.0.255 access-list 103 permit ip host 192.168.2.100 any access-list 103 permit ip host 195.122.201.48 any access-list 103 permit ip host 195.122.207.102 any ! ! tftp-server flash:SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn tftp-server flash:DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn tftp-server flash:spa50x-30x-7-5-4.bin alias spa50x-30x-7-5-4.bin tftp-server flash:spa525g-7-5-4.bin alias spa525g-7-5-4.bin tftp-server flash:spa525g-7-5-4-bt.bin alias spa525g-7-5-4-bt.bin tftp-server flash:SCCP69xx.9-4-1-3SR2.zz.sgn alias SCCP69xx.9-4-1-3SR2.zz.sgn tftp-server flash:DSP69xx.12-4-122-99.131025.zz.sgn alias DSP69xx.12-4-122-99.131025.zz.sgn ! control-plane ! call threshold global cpu-avg low 68 high 75 call threshold global total-mem low 75 high 85 call threshold global total-calls low 8 high 10 ! ! ! mgcp profile default ! ! dial-peer voice 1 voip translation-profile incoming IN session protocol sipv2 session target dns:sip.sipserver.net incoming called-number .% no voice-class sip tel-config to-hdr dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 2 voip description "Outgoing ... " translation-profile outgoing OUT destination-pattern 9T session protocol sipv2 session target dns:sip.sipserver.net dtmf-relay sip-notify rtp-nte codec g711alaw no vad ! ! presence ! gateway timer receive-rtp 1200 ! sip-ua sip-server dns:sip.sipserver.cz credentials number XXX username XXX password 7 XXX realm sip.sipserver.net keepalive target dns:sip.sipserver.cz authentication username XXX password 7 XXX realm sip.sipserver.net retry invite 2 retry register 2 timers connect 100 registrar dns:sip.sipserver.cz expires 3600 ! ! ! gatekeeper shutdown ! ! telephony-service no auto-reg-ephone max-ephones 50 max-dn 100 no-reg both ip source-address 10.20.52.1 port 2000 max-redirect 5 timeouts interdigit 5 timeouts busy 5 cnf-file location flash: load 6921 SCCP69xx.9-1-1-0.loads load 6941 SCCP69xx.9-1-1-0.loads load 6961 SCCP69xx.9-1-1-0.loads time-format 24 date-format dd-mm-yy dialplan-pattern 1 5880083.. extension-length 2 extension-pattern .. max-conferences 8 gain -6 call-forward pattern .T dn-webedit time-webedit transfer-system full-consult transfer-pattern .T create cnf-files version-stamp 7960 Sep 01 2020 16:10:06 ! ! ephone-dn 1 number 33 no-reg primary description Vedouci provozu name Vedouci provozu ! ! ephone-dn 2 number 20 no-reg primary description Spravce IT name Spravce IT ! ! ephone-dn 3 number 22 no-reg primary description Spravce MaR name Spravce MaR ! ! ephone-dn 4 number 24 no-reg primary description Sklad name Sklad ! ! ephone-dn 5 number 23 no-reg primary description Administrativa name Administrativa ! ! ephone-dn 6 number 25 no-reg primary description CHUV name CHUV ! ! ephone-dn 7 number 21 no-reg primary description Spravce elektro name Spravce elektro ! ! ephone 1 mac-address 2C54.2D6A.98E4 max-calls-per-button 2 provision-tag 1 speed-dial 1 9588008040 label "Reditel" speed-dial 2 9588008041 label "Sekretariat" type 6921 button 1:1 ! ! ! ephone 2 mac-address 2C54.2D6A.98EF max-calls-per-button 2 provision-tag 2 speed-dial 1 9588008041 label "Miriam" speed-dial 2 9777028067 label "Mobil" type 6921 button 1:2 ! ! ! ephone 3 mac-address 2C54.2D6A.AB7E max-calls-per-button 2 provision-tag 3 type 6921 button 1:3 ! ! ! ephone 4 mac-address 2C54.2D6A.C230 max-calls-per-button 2 provision-tag 4 type 6921 button 1:4 ! ! ! ephone 5 mac-address 2C54.2D6A.B4F0 max-calls-per-button 2 provision-tag 5 type 6921 button 1:5 ! ! ! ephone 6 mac-address 2C54.2D6A.BB26 max-calls-per-button 2 provision-tag 6 type 6921 button 1:6 ! ! ! ephone 7 mac-address 2C54.2D6A.C22D max-calls-per-button 2 provision-tag 7 type 6921 button 1:7 ! ! ! ! line con 0 line aux 0 line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 login local transport input telnet ssh ! scheduler allocate 20000 1000 ntp server 194.160.23.2 end
09-02-2020 06:42 AM
So another progress for the problem number 2 - I have added the following lines to the "voice service voip":
ip address trusted list ipv4 0.0.0.0 0.0.0.0
Now, the CME is sending back "SIP/2.0 404 Not Found":
Sep 2 14:38:13.701: //7019/006E13C7915B/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 404 Not Found Via: SIP/2.0/UDP 195.122.207.107:5060;branch=z9hG4bK-OUQE-c4011c99-787294f7 From: "777028067" <sip:777028067@sip.sipserver.cz;user=phone>;tag=13241-CQ-32179313-0cc3bbf55 To: <sip:588008341@195.122.207.107:5060;user=phone>;tag=4D2D870-1267 Date: Wed, 02 Sep 2020 12:38:13 GMT Call-ID: 13241-ZT-32179312-2555cc825@sip.sipserver.cz CSeq: 602883599 INVITE Allow-Events: telephone-event Server: Cisco-SIPGateway/IOS-12.x Reason: Q.850;cause=1 Content-Length: 0
Can you please help me with this?
Thank you very much.
09-02-2020 07:56 AM
Now when I try to debug with voip ccapi, I get the following log:
Sep 2 15:48:42.235: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata: CALL_ERROR; Avlist Set Is Failed Sep 2 15:48:42.235: //-1/D8D52C5892B9/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username=777028067 ----- ccCallInfo IE subfields ----- cisco-ani=777028067 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=588008311 cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=-1 cisco-rdnsi=-1 cisco-redirectreason=-1 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 Sep 2 15:48:42.235: //-1/D8D52C5892B9/CCAPI/cc_api_call_setup_ind_common: Interface=0x3122A798, Call Info( Calling Number=777028067,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=588008311(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=7487 Sep 2 15:48:42.235: //-1/D8D52C5892B9/CCAPI/ccCheckClipClir: In: Calling Number=777028067(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Sep 2 15:48:42.235: //-1/D8D52C5892B9/CCAPI/ccCheckClipClir: Out: Calling Number=777028067(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) Sep 2 15:48:42.235: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Sep 2 15:48:42.235: :cc_get_feature_vsa malloc success Sep 2 15:48:42.235: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Sep 2 15:48:42.235: cc_get_feature_vsa count is 1 Sep 2 15:48:42.235: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: Sep 2 15:48:42.235: :FEATURE_VSA attributes are: feature_name:0,feature_time:732270664,feature_id:85 Sep 2 15:48:42.235: //7487/D8D52C5892B9/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=777028067(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=588008311(TON=Unknown, NPI=Unknown)) Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/cc_process_call_setup_ind: Event=0x313CA5C8 Sep 2 15:48:42.239: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search: Try with the demoted called number 588008311 Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/ccCallSetContext: Context=0x31B3AAEC Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 7487 with tag 1 to app "_ManagedAppProcess_Default" Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/ccCallProceeding: Progress Indication=NULL(0) Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/ccCallDisconnect: Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0) Sep 2 15:48:42.239: //7487/D8D52C5892B9/CCAPI/ccCallDisconnect: Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1) Sep 2 15:48:42.275: //7487/D8D52C5892B9/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x3122A798, Tag=0x0, Call Id=7487, Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0) Sep 2 15:48:42.279: //7487/D8D52C5892B9/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent Sep 2 15:48:42.279: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Sep 2 15:48:42.279: :cc_free_feature_vsa freeing 2BA59040 Sep 2 15:48:42.279: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: Sep 2 15:48:42.279: vsacount in free is 0 Sep 2 15:51:42.280: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode: ccAppShutdownMode: remove it from the queue
It looks like the CME is getting the wrong Called Number - 588008311 is the number from the top part (header?) of the INVITE message, but in the correct number of from the "To:" part of the message. How to configure the CME to get the Called Number from the "To" part of the SIP INVITE message?
