Connect Panasonic PBX to CUCM 6.1 via E1
parinya
Hi, Is there anyone had an experience in connect Panasonic PBX to CUCM 6.1? Due to the interoperability portal on CCO have no information about Panasonic. It'll be great if someone share us the configuration of CUCM.
gogasca
Level 10
Level 10
Which model of panasonic
E1 which protocol on Panasonic and which protocols it support?
Best site to get info about Panasonic is panasonic.
From ccm pickup any guide and you will have lot of info depending what ur modle supports
Let us know which model so we can tell u if we have performed some tests
Thanks for the reply.
The model is PANASONIC TDA600
