Connecting an IP Phone to a VoIP provider or POTS line
jeff000011111
I am trying to interface an IP phone with autodialing capabilities (a Viking E-30-IP) either to a VoIP provider or POTS line. The IP phone is some distance from the main LAN and I will connect it using Nanostation M2 transceivers (which will also carry a video signal from cameras to the LAN).
I have a VoIP account with CallCentric but cannot interface the two systems as the E-30-IP requires the IP address of the provider and CallCentric only allows connection via its domain name - callcentric.com.
Is there a device that has a configurable IP address will see the signals from the E-30-IP and connect in turn to the VoIP provider?
As an alternative, is there a device that the E-30-IP can connect with which will connect to a POTS line?
Either way will work for my application.
Many thanks for any suggestions...
Jeff
0 Replies 0
