CP-8861 Running SSL VPN
Greetings,
I have been asked to deploy a pair of 8861's and have them SSL VPN back to the CME.  I recall with the 7975, it had to terminate on an ASA and I am assuming this is still true but please correct me if I am wrong.  Also I would like to know if there are any special considerations with regards to traffic SIP and or SCCP between the 8861 and the CME/CUE once the SSL is up.
I have been unsuccessful with locating a guide or document regarding this spacific product.
Cheers,
-michael
rvarelac
Level 7
Level 7
Hi Michael,
Yes, the VPN configuration for this model of phone is the same as the 7975, check the links below for examples:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/8841_8851_8861/10_5/english/DeploymentGuide/CiscoIPPhone8800SeriesWLANDeploymentGuide.pdf
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/115785-anyconnect-vpn-00.html
I don't think we need a special configuration for the SIP and SCCP traffic over the VPN , the VPN traffic is handle equally by the network devices until it is decrypted.
Hope it helps
-Randy-
