04-06-2020 09:31 AM
my name is Florian and i am relatively new to the Cisco world and this community.
I recently purchased a used 1861 and i try to connect my 7970G to the CME.
The phone gets ip config via DHCP and option 150 but doesn't register at all.
I did this in packet tracer with 7960s several times. But in the real live i don't have any success unfortunately.
I also got some 8961s here but first i want to bring my 7970 to life.
I tried like 15 hrs to figure it out.
If someone can help me / give me a hint what i am doin wrong i would be so thankful.
My config and sh versions are below
R1#sho run Building configuration... Current configuration : 3275 bytes ! ! Last configuration change at 05:13:01 Berlin Mon Apr 6 2020 ! NVRAM config last updated at 05:13:07 Berlin Mon Apr 6 2020 ! version 15.0 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname R1 ! boot-start-marker boot-end-marker ! ! no aaa new-model ! ! ! clock timezone Berlin 2 network-clock-participate wic 1 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ! ! dot11 syslog ip source-route ip cef ! ! ip dhcp excluded-address 10.2.1.1 10.2.1.99 ip dhcp excluded-address 10.1.1.1 10.1.1.99 ! ip dhcp pool dPool network 10.2.1.0 255.255.255.0 default-router 10.2.1.1 dns-server 10.1.1.1 ! ip dhcp pool vlan1pool import all network 10.1.1.0 255.255.255.0 default-router 10.1.1.1 dns-server 192.168.8.1 option 150 ip 10.1.1.1 ! ! ip name-server 192.168.8.1 ip name-server 8.8.8.8 no ipv6 cef ! ! ! ! ! multilink bundle-name authenticated ! ! ! ! voice register global ! ! ! ! voice-card 0 ! ! ! license udi pid C1861-SRST-B/K9 sn FHK150275ZS vtp mode transparent ! ! controller SHDSL 0/2/0 termination cpe ! vlan 2,10,20 ! vlan 220 name db-energie ! ! ! ! ! ! ! ! ! interface FastEthernet0/0 description WAN-Link ip address dhcp ip nat outside ip virtual-reassembly duplex auto speed auto ! ! interface FastEthernet0/1/0 ! ! interface FastEthernet0/1/1 ! ! interface FastEthernet0/1/2 ! ! interface FastEthernet0/1/3 ! ! interface FastEthernet0/1/4 ! ! interface FastEthernet0/1/5 ! ! interface FastEthernet0/1/6 ! ! interface FastEthernet0/1/7 ! ! interface FastEthernet0/1/8 ! ! interface BRI0/1/0 no ip address ! ! interface BRI0/1/1 no ip address ! ! interface Vlan1 ip address 10.1.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ! ! ip forward-protocol nd ip http server ip http authentication local no ip http secure-server ip http path flash: ! ! ip nat inside source list 1 interface FastEthernet0/0 overload ip route 0.0.0.0 0.0.0.0 192.168.8.1 ip ospf name-lookup ! access-list 1 permit 10.1.1.0 0.0.0.255 ! ! ! ! ! tftp-server flash:P00307020300.bin tftp-server flash:/phone/7970-7971/apps70.8-3-2-27.sbn alias apps70.8-3-2-27.sbn tftp-server flash:/phone/7970-7971/cnu70.8-3-2-27.sbn alias cnu70.8-3-2-27.sbn ! control-plane ! ! ! voice-port 0/0/0 ! voice-port 0/0/1 ! voice-port 0/0/2 ! voice-port 0/0/3 ! voice-port 0/1/0 ! voice-port 0/1/1 ! voice-port 0/4/0 auto-cut-through signal immediate input gain auto-control description Music On Hold Port ! ! mgcp fax t38 ecm mgcp behavior g729-variants static-pt ! ! ! ! ! telephony-service max-ephones 12 max-dn 12 ip source-address 10.1.1.1 port 2000 system message Hi There! max-conferences 4 gain -6 web admin system name admin password cisco dn-webedit time-webedit transfer-system full-consult create cnf-files version-stamp 7960 Mar 28 2020 13:31:47 ! ! ephone-dn 1 number 111 ! ! ephone-dn 2 number 222 ! ! ephone 1 device-security-mode none mac-address 0014.A934.1947 button 1:1 ! ! ! ephone 2 device-security-mode none mac-address 1CAA.0710.0CAF button 1:2 ! ! ! line con 0 no modem enable line aux 0 line vty 0 4 login ! ntp master ntp server 192.168.8.1 ntp server 132.163.96.5 ntp server 64.209.210.20 end
R1#sh telephony-service CONFIG (Version=8.0) ===================== Version 8.0 Cisco Unified Communications Manager Express For on-line documentation please see: http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html protocol mode default ip source-address 10.1.1.1 port 2000 ip qos dscp: ef (the MS 6 bits, 46, in ToS, 0xB8) for media cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal af41 (the MS 6 bits, 34, in ToS, 0x88) for video default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup max-ephones 12 max-dn 12 max-conferences 4 gain -6 dspfarm units 0 dspfarm transcode sessions 0 conference software privacy no privacy-on-hold hunt-group report delay 1 hours hunt-group logout DND max-redirect 10 cnf-file location: system: cnf-file option: PER-PHONE-TYPE network-locale[0] US (This is the default network locale for this box) network-locale[1] US network-locale[2] US network-locale[3] US network-locale[4] US user-locale[0] US (This is the default user locale for this box) user-locale[1] US user-locale[2] US user-locale[3] US user-locale[4] US srst mode auto-provision is OFF srst ephone template is 0 srst dn template is 0 srst dn line-mode single time-format 12 date-format mm-dd-yy timezone 0 Greenwich Standard Time no transfer-pattern is configured, transfer is restricted to local SCCP phones only. R1#dir flash: Directory of flash:/ 1 -rw- 840 Mar 11 2020 22:10:06 +02:00 vlan.dat 2 -rw- 44471336 Jun 30 2011 16:27:14 +02:00 c1861-advipservicesk9-mz.150-1.XA1.bin 3 -rw- 49009680 Jun 3 2014 12:49:42 +02:00 c1861-advipservicesk9-mz.151-4.M6.bin 129744896 bytes total (36253696 bytes free) sh version Cisco IOS Software, C1861 Software (C1861-ADVIPSERVICESK9-M), Version 15.0(1)XA1, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2009 by Cisco Systems, Inc. Compiled Fri 18-Dec-09 14:25 by prod_rel_team ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1) R1 uptime is 3 weeks, 8 hours, 42 minutes System returned to ROM by power-on System restarted at 20:31:53 Berlin Sun Mar 15 2020 System image file is "flash:c1861-advipservicesk9-mz.150-1.XA1.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco C1861-SRST-B/K9 (MPC8358) processor (revision 0x300) with 249856K/12288K bytes of memory. Processor board ID FHK150275ZS MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20 12 User Licenses 1 DSL controller 10 FastEthernet interfaces 2 ISDN Basic Rate interfaces 1 Virtual Private Network (VPN) Module 4 Voice FXS interfaces 1 Voice MoH interface 128K bytes of non-volatile configuration memory. 126976K bytes of ATA CompactFlash (Read/Write) License Info: License UDI: ------------------------------------------------- Device# PID SN ------------------------------------------------- *0 C1861-SRST-B/K9 FHK150275ZS Configuration register is 0x2142
