07-10-2009 06:11 AM - edited 03-15-2019 06:55 PM
I'm getting mixed information from two parties. Can someone who has implemented Media Flowaround with SIP to SIP deployments tell me if it is supported with G729? The documentation doesn't really say much about the limitations.
THXS
07-13-2009 09:33 AM
Hi Kelvin,
In media flow-around the CUBE is not involved at all with the media, and the cube should not have any type of issues with this.
-nick
07-13-2009 09:39 AM
That is what I thought, but the issue that has been mention is due to different types of signaling. For Example Delay Offer to Delay offer has no issue. Early offer to Early offer has no issue. Since UCM 6.X only sends a Delay offer and the provider expects early offer the need to change the type of signaling at the CUBE is needed. Since the original leg differs from the final leg I was told it would not work. With that being said, if it is SIP to SIP with Delay to Early is the media flowaround still supported for G729?
07-13-2009 10:27 AM
Hi Kelvin,
DO-EO flow-around is not supported for SIP-SIP gateways. This is in the restrictions here:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip.html#wp1309838
Cisco IOS Release 12.4(9)T and later releases:
â¢Media flow-around for Delayed-Offer to Early-Offer audio and video calls is not supported.
It looks like for flow-around you would need to enable MTP on your CUCM SIP trunk, or have your provider accept delayed offers. I'm guessing the former will be simpler.
hth,
nick
07-13-2009 10:30 AM
Yep.. Read the same thing. Just making sure I wasn't reading that incorrectly.
Thanks!
