CUBE SIP transfer-hold error
carlos_Canepa
ello Guys,
I´m having issues when performing hold or transfers via sip provider.
The scenario is like this: PHONEA-CUCM-CUBE-SIP PROVIDER
When PHONEA receive a call,from outside (sip provider), if the user puts the call on hold/transfer, the user does not hear any music on hold, or dialtone, so the call cutsoff by time.
But if PHONEA does not use Hold/transfer the call works ok.
The calling number is 45903700 and the called number is 4000 (20354000)
Thanks in advance
Did you disable supplementary service refer and 302 on cube
no supplementary-service sip refer
no supplementary-service sip 302
Hi Mohammed,
Thanks for your reply I will test it and come back with the results.
Regards.
