04-27-2015 07:40 AM - edited 03-17-2019 02:49 AM
Is the CUCI Lync product compatible with Skype for Business Server 2015? We have UCM 9.1.3 and are on MS Outlook 2013 and are thinking of moving to Skype for Business Server 2015.
07-03-2015 12:25 PM
Our organization is moving from old PBX to Cisco HCS solution and planning to install CUCILYNC 10.6, So wondering if it is compatible with Skype for business
Please advice
Faiz
07-03-2015 02:04 PM
http://docwiki.cisco.com/wiki/CUPS/IM%26P_FAQ#Can_I_integrate_with_Skype_for_Business.3F.3F
07-03-2015 07:29 PM
Hi Jamie
Thanks for your prompt reply, another thought if we have Lync server 2013 at back end and client facing is skype for business 2015 . then...?
Faiz
07-04-2015 08:32 AM
We have no client for Skype for Business, but if you still have Lync (not even sure if that's possible, I understood you had to go all elements to skype for business) then you could have an XMPP federation.
