CUCM 10.5 LDAP question
George Banuelos
Hi all,
Question regarding CUCM 10.5 LDAP integration:  There are 2 CUCM 10.5 clusters that will be LDAP integrated to a single OU.  How can it be set-up so that each CUCM will only sycnh its user base with corresponding members at their physical location and not entire OU user base?  For example:  1 OU includes users at 4 sites.  Two of these sites have CUCM 10.5 clusters and two have other systems.  The intent is for each CUCM user base to include only users at their own locations and not the entire OU.   Please advise.
Thank you!
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
Jaime Valencia
duplicate
https://supportforums.cisco.com/discussion/12315336/cucm-105-ldap-question
java
if this helps, please rate
