06-18-2008 11:17 PM - edited 03-15-2019 11:22 AM
we have a problem with the direct pickup with the BLF button in CUCM 6.1(2). After a call comes in and I want to pick it by pressing the flashing BLF button there is a "Temp Fail" displayed on the phone.
By pressing the Pickup Softkey and then the BLF button it works, but thats not how it should work.
Anyone got the same issue?
Cheers
Moe
06-19-2008 02:26 AM
Hi Moe,
we are using 6.1(2) with BLF Pickup and it works. You have to set the checkbox at the BLF, you have to scroll to the right corner to see it.
Axel
05-11-2009 03:29 AM
I have a cluster that has the following version: 6.1.3.1000-16.
My problem is that the pickup checkbox is not shown.
any clue why?
Nick
05-11-2009 05:02 AM
as far as I know this is only working with SCCP, not SIP.
Axel
05-11-2009 05:13 AM
Hi Axel,
I'm using phones running SCCP.
Nick
09-29-2009 04:38 AM
I had the same issue and that was because the pickup DN was in partition
I've configured a partition reachable by the phone and it makes it to work.
hope this helps...
