05-30-2011 04:39 AM - edited 03-16-2019 05:12 AM
We have here a 7.0(2) CUCM cluster, and now we are trying to change the CDR source to a different one and the page times out. At the end it shows "Connection error - Invalid directory path" but I think that this is not the real problem since the SFTP server has no subdirectories.
I am trying with WinSCP and I can get connected to the root folder, and from the CUCM it seems to be that the connectivity is also good.
I have seen in other threads that the "CDR Repository Manager" traces are necessary to make some troubleshooting but what I see doesn't help me too much. I also took CDR agent traces and they didn't help either
Any ideas of what can be happening? I am attaching the CDR repository manager log to the thread
Daniel
05-31-2011 12:10 AM
Well, in the end it seems to be a problem with the SFTP / FTP server used.
Can anybody recommend one good server for Linux?
05-31-2011 12:44 AM
05-31-2011 12:48 AM
Hello Ashok
Thanks for your answer, but this is the one that the customer is using and it does not work. When I use freeftpd on a windows server it works. Have you tried it before with CUCM?
They use OpenSSH 5.4
regards,
Daniel
