CUCM 7.1.3 sql script
m.ateeque
is there a way to get a  list of calls made for a particular number i.e 911 etc. we have 6 sites using MGCP on voice gateways, reading from various  blogs i understood we can use run sql command on pub/sub to send a query and get results, apprecaite if anyone on these forum can point me into right direction or a sample script will be helpful.
13 Replies 13
Jaime Valencia
You can just use CAR for that
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
What is CAR ? how do i use it to find out called details,
Cisco Unified CDR Analysis and Reporting  Administration Guide, Release 7.1(2)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/CAR.html
java
java
Vipul Jindal
try the below on CLI of call manager
run sql car select callingpartynumber,originalcalledpartynumber,finalcalledpartynumber,datetimestamporigination from tbl_billing_data where originalcalledpartynumber IN('911','9911') or finalcalledpartynumber IN ('911','9911')
thanks,
Vipul Jindal
if this helps, please rate!!
Vipul, im  getting syntax error, runnign query from pub
admin:run sql car select callingpartynumber,originalcalledpartynumber,finalcalldpartynumber,datetimestamporigination from tbl_billing_data where originalcallepartynumber IN('911','9911') or finalcalledpartynumber IN ('911','9911')
A syntax error has occurred.
try this one
run sql car select callingpartynumber,originalcalledpartynumber,finalcalledpartynumber, datetimeorigination from tbl_billing_data where originalcalledpartynumber IN ('911','9911') or finalcalledpartynumber IN ('911','9911')
thanks,
Vipul Jindal
i have accessed PUB throgh putty and copy/paste your command from Admin: im still getting syntax error,
dont copy/paste it..write it down...also check if the car service is running on the server or not!!
i tried the same in my lab and it worked!!
thanks,
Vipul Jindal
thanks for thequick update, these time i did type the entire command, please see below details.
admin:run sql car select callingpartynumber,originalcalledpartynumber,finalcalledpartynumber, datetimeorigination from tbl_billing_data where originalcalledpartynumber IN ('911','9911') or finalcalledpartynumber IN ('911','9911')
admin:run sql car select ?
Syntax:
run sql sql_statement
sql_statement mandatory  the sql command to run
do you have CAR service running on the server??
I think the issue is that Vipul is running his query on a CUCM 8.x system the OP has a CUCM 7.1.3 system. At least, according the title of the thread it is 7.1.3.
In 7.1.3, you would use this query:
admin:run sql select callingpartynumber,originalcalledpartynumber,finalcalledpartynumber,datetimeorigination from car:tbl_billing_data where originalcalledpartynumber IN ('911','9911') or finalcalledpartynumber IN ('911','9911')
HTH.
Bill
please rate helpful posts
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks much Bill,  i really appreciate your help, i was able to run your script succesfully, with  one obstacle datetime is appearing as " 1323803298" i tried converting file to .csv import in excel, didn't work,  yes as the title of these discussion i did mentioned cucm version 7.1.3, bill,  thanks for amazing informatic articles...great work, finally where can i find the  "callingpartynumber originalcalledpartynumber finalcalledpartynumber datetimeorigination" etc.  if i need to trim or include few other fields in my query.
Yes, date/time will appear as epoch time. In Excel, you may be able to use this formula to convert the data value. Add a new column, insert the formula in one of the cells and paste down.
*=(((A1-(6*3600))/86400)+25569)*
The above assumes that cell A1 has the date/time field you wish to convert.
You may also need to change the format the cells which hold the formula (e.g. dd/mm/yyyy hh:mm).
In regards to what fields are in the CDR table, see the following:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/cdrdef/cdrfdes.html
HTH.
Bill
