CUCM 7.x CDR flat file billing server
walker-ryan
Hi all,
Is it possible to specify what infromation is logged in the flat file sent to the CDR record?  Also I am looking but unable to find a field within the flat file weather the call was onnet or offnet specifically is there not a filed that says DN 5555 called 1+(10digit) long distance for billing purposes.  I do see the calling and called numbers but appear to be getting both incoming and outgoing in both fields.
Ryan
Jaime Valencia
There is no way to modify or customize the flat files. All the fields are pre-defined.
CAR has a dial plan which you can configure to match calls depeding on dialing habits.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
