CUCM/7821 EAP-TLS Radius issues.
m.dehkordy
Hello.
We are attempting to get our 7821 phones to authenticate with a Windows 2012 NPS radius server using EAP-TLS.
CUCM (v9.1) is running in mixed mode, our test phone has a LSC certificate.
Unfortunately nothing we seem to try is working.
We have used wireshark to try and intercept communication between RADIUS and Switch -  and it seems as though the two are passing certificate information between each other.
However when using EAP tracing on the windows server we see the following error messages.
[3436] 03-26 15:12:19:532: AuthenticateUser
[3436] 03-26 15:12:19:532: DwGetEKUUsage
[3436] 03-26 15:12:19:532: GetEKUUsage
[3436] 03-26 15:12:19:532: Number of EKUs on the cert are 3
[3436] 03-26 15:12:19:532: FCheckPolicy
[3436] 03-26 15:12:19:548: CertVerifyCertificateChainPolicy succeeded but policy check failed 0x800b0110.
[3436] 03-26 15:12:19:548: FCheckPolicy done.
[3436] 03-26 15:12:19:548: The user's cert does not have correct usage.
[3436] 03-26 15:12:19:548: MakeAlert(49, Manual)
[3436] 03-26 15:12:19:548: State change to SentFinished. Error: 0x800b0110
Wireshare seems to be indicate the server certificate (which has all EKU roles assigned) and the CAPF certificate (which only seems to have two EKU roles assigned to it) are being used in the exchange.
Are we missing something? Does the CAPF certificate need modifiying to support more EKUs? Or are we heading in completly the wrong direction?
Thanks.
**edit**
To add to this, these are the EKU's the certificate has.
  Extensions: 3 present
     Extension: KeyUsage (OID.2.5.29.15)
     Critical: false
     Usages: digitalSignature, keyEncipherment, keyCertSign,
     Extension: ExtKeyUsageSyntax (OID.2.5.29.37)
     Critical: false
     Usage oids: 1.3.6.1.5.5.7.3.1, 1.3.6.1.5.5.7.3.5,
     Extension: SubjectKeyIdentifier (OID.2.5.29.14)
     Critical: false
     keyID: 392b33381247e0d2ecb891d317e72af7463d2faf
If I use the MIC certificate for authentication, it gets further, but presents a different error.
[788] 03-27 10:17:39:706: AuthenticateUser
[788] 03-27 10:17:39:706: DwGetEKUUsage
[788] 03-27 10:17:39:706: GetEKUUsage
[788] 03-27 10:17:39:706: Number of EKUs on the cert are 0
[788] 03-27 10:17:39:706: FCheckPolicy
[788] 03-27 10:17:39:706: FCheckPolicy done.
[788] 03-27 10:17:39:706: FCheckUsage: All-Purpose: 1
[788] 03-27 10:17:39:706: CheckUserName
[788] 03-27 10:17:39:706: QuerySecurityContextToken failed and returned 0x8009030b
[788] 03-27 10:17:39:706: MakeAlert(49, Manual)
[788] 03-27 10:17:39:706: State change to SentFinished. Error: 0x8009030b
Mateusz Pagacz
May be related to https://tools.cisco.com/bugsearch/bug/CSCuo40169.
Can you give it a test using anything other than 78xx and let us know if it works?
I am afraid I don't have anything other than 7821's to test with.
The 7821's work with FreeRadius and the MIC certificates
The issue I think is with incompatibilties with NPS and the LSC certificate not having the appropriate usages.
Hi, i have the same problem even with MIC certificates.
Did you succeed with MIC?
On my side i have this kind of error "User not found"
