CUCM 8.6 WEBADMIN ERROR
rustomhind
I have a CUCM version 8.6. It was working fine for a couple of month and then suddenly one day there is the below error.
Command Line Interface is starting up, please wait ...
   Welcome to the Platform Command Line Interface
Exception in thread "main" java.lang.NumberFormatException: For input string: ""
        at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
        at java.lang.Integer.parseInt(Integer.java:470)
        at java.lang.Integer.<init>(Integer.java:660)
        at com.cisco.platform.install.ihardware.Hardware.getDiskSize(Hardware.java:319)
        at sdMain.main(sdMain.java:764)
The phone are registering. I can even see the opening page which says installed products. But after I click on CUCM it shows me a blank page. the url for the blank page is
https://<ip add of cucm>:8443/ccmadmin/showHome.do
The CLI is frozen after the above message is displayed. I tried to SSH into the machine. Same problem. I tried searching supportforums.cisco.com for a similar issue. Did not find one. In case such a case exists, do point me out in that direction.
Having the same issue if some can help
