CUCM - Bulk Update by Phone's Registered IP Address
Lucas Phelps
Level 5
Level 5
I'd like to update many phones registered to our CUCM.  I'd like to set the 'Device Pool' based on the first 3 octects of the phone's IP address.
For example, if the phone is registered with an IP of 192.168.15.2    15 is my ACME office and I'd like them to be in my ACME Device Pool.
Any thoughts on how to do this?
Jaime Valencia
BAT has no way to use the IP as a filter, you'd need to filter by one of the available options in BAT if you plan to use a query, or to manually create your file for the update.
If you have properly configured the location on your devices, you can use that value.
java
if this helps, please rate
