CUCM Publisher Failure
Afternoon all,
Does anyone know that in this scenaria if a Pub fails, can you make a Sub become a semi-permanent replacement &
permanent replacement?
Cheers.
Jaime Valencia
No, that's not currently possible. You need to rebuild your PUB to be able to admin the cluster back again.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I thought so, however I am sure there was talk that this would be available in the latter UCM s/w. Mad that its not.
Thanks for the reply!
