cucm sql command to update line description
Hi every one,
I have cucm ver 10.5.2 with around 200 users (200 extensions) and need to update directory numbers line Description, Alerting Name, ASCII Alerting Name, Display (Caller ID), ASCII Display (Caller ID) and Line Text Label.
How to do all these by sql command? if not possible what is proper way to do it?
Jaime Valencia
You should use BAT or AXL for that, SQL is not recommended to perform configuration changes, unless instructed by Cisco TAC.
java
if this helps, please rate
Thanks for reply Jaime, could you please mention a refernce to do such update by alx
