CUE auto attendant busy signal
hello
i have a problem with cisco unity express auto attendant , i get a busy signal when making call to AA extension
debug ccsip all:
Mar 13 12:48:42.757: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2B83DFD0) with key=[16958] to table
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Mar 13 12:48:42.757: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Mar 13 12:48:42.757: //605598/000000000000/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Mar 13 12:48:42.757: //605598/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.757: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sip_md:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sip_ed:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_early_dialog_container
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.761: //605598/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 12:48:42.761: //605598/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.2.252 target_port : 5060
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [-8] in dial-peer [2001]
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 93D9E to table
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=605597
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.2.253
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 28348 for stream 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Mar 13 12:48:42.761: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Mar 13 12:48:42.761: //605598/2BA783CFABD9/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.2.253
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2B83DFD0 key=2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.2.252,Port 5060, Transport 2, SentBy Port 5060
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:3246A5BC
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLMain:
    SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
    Configured SE:1800, Configured Min-SE:1800
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_process_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_handle_network_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_process_event:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (605598) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPISendInvite: Associated container=0x3246A5BC to Invite
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: msg=0x2B96BE78, addr=192.168.2.252, port=5060, sentBy_port=0, local_addr=192.168.2.253, is_req=1, transport=2, switch=0, callBack=0x251CB50C
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x2AF8EDE0,addr=192.168.2.252
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnHolder: Created new holder=0x2AF8EDE0, addr=192.168.2.252; nailed=FALSE
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting TCP conn create request for addr=192.168.2.252, port=5060, context=0x3177B244
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x2AEC1ABC,addr=192.168.2.252, port=5060
Wait Conn Timer started for 5000 msec
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x2AEC1ABC, connid=-1, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, transport=TCP
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.2.252, rport:5060 with laddr:192.168.2.253
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x2B83DFD0 with connection=0x2AEC1ABC
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Transport/sipSPITransportSendMessage: Deferred sending msg=0x2B96BE78
Mar 13 12:48:42.765: //605598/2BA783CFABD9/SIP/Info/sipSPIUpdateCallEntry:
Call 605598 set InfoType to SPEECH
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 56
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionCreated: context=0x3177B244
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: gConnTab=0x3177B244, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connid=3, transport=TCP
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:192.168.2.252, port:5060 local_addr=192.168.2.253 local_port=50234
Mar 13 12:48:42.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x2AEC1ABC, connid=3state to pending
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:192.168.2.252, port:5060)
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 57
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionFailed: context=0x3177B244
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnFailed: gConnTab=0x3177B244, addr=192.168.2.252, port=5060, local_addr = 192.168.2.253, transport=TCP
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x2AEC1ABC,addr=192.168.2.252, port=5060
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=1
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting TCP conn close for addr=192.168.2.252, port=5060, local_addr=192.168.2.253, connid=3
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x2AEC1ABC, connid=3, addr=192.168.2.252, port=5060, local_addr=192.168.2.253, transport=TCP
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 61
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Error/sipTransportPostSendFailure: Posting send failure msg
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 53
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_send_msg_failure: Send Error to 192.168.2.252:5060 for transport TCP
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:38, category:186
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[605598], src[6]
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(38) for outgoing call
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_purge_entry: Socket fd: 0 closed for connid 3 with address: 192.168.2.252, remote port: 5060
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/Session-Timer/sipSTSLMain:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:90740177 ConnTime 0
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/State/sipSPIChangeState: 0x2B83DFD0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2B83DFD0
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           :
Called Number            : 400
Source IP Address (Sig  ): 192.168.2.253
Destn SIP Req Addr:Port  : 192.168.2.252:5060
Destn SIP Resp Addr:Port : 192.168.2.252:5060
Destination Name         : 192.168.2.252
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.2.253
Source IP Port    (Media): 28348
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 93D9E
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[16958] removed.
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x2B83DFD0 key=2BA8BC1F-8B1311E2-ABDEE1AE-D7673161@192.168.2.253
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_offer_ans_delete:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/ccsip_iwf_delete:
Mar 13 12:48:42.769: //605598/2BA783CFABD9/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 2B83DFD0
Mar 13 12:48:42.769: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[16958]
15 Replies 15
SIP Gateway:                            192.168.2.253
SIP Port Number:                        5060
DTMF Relay:                             sip-notify,sub-notify
MWI Notification:                       outcall,sub-notify
MWI Envelope Info:                      enabled
Transfer Mode:                          bye-also
Transfer Timeout:                       6
SIP RFC Compliance:                     Pre-RFC3261
