Delay in GW calls
madan.kumar
We are having CCM 5.X and the H323 GW& Phones located over the WAN.CUG calls are fine but there is 3 sec intial delay in the PSTN calls.
CCM(L0CATION1)------>PHONES,GW(LOCATION2)
WAN
Please find the GW config and the ping & sh call active coice details
6 Replies 6
Michael Owuor
Hi Madan,
Try the following steps to see if you get an improvement in the call setup time.
1. Uncheck 'Wait for Far End H.245 Terminal Capability Set' on the gateway configuration page in CCMAdmin, so that CallManager will send TCS without waiting for the other side.
Also check the 'Enable Outbound FastStart' option on the H.323 gateway configuration in CCMAdmin.
Reset the gateway in CCMAdmin and then test again.
Michael.
Hi Michael,
Thanks for the input will try and let you know
Madan
Hi Michael
I just got a update from customer that after doing the above mentioned changes also still the problem persists.I can see the H323 source bind address is not configured in the GW interface.Do you suggest configuring same.Pleas let me know your inputs
Madan
Hi Madan,
Sure, go ahead and add the H323 source bind address command. When testing again, please see if you can collect the output of these two commands. Hopefully that output will show us where the delay is taking place.
- debug cch323 h225
- debug cch323 h245
The Detailed CCM traces collected from the CallManager during the same test call will give the view of the problem from the CallManager's perspective, so that might also be useful as well.
Hope all is well.
Michael.
Get the Honda, don't get the Ford, you'll thank me later.
Rate this post if this was helpful.
Hi Michael,
Pls find the H323 debugs let me know your inputs
Madan
