Delete Locale on Call Manager 6.0
svuddanti
I need to delete locales on Call Manager 6.0. If anyone know how to do this please help me.
gogasca
Level 10
Level 10
CCM Admin -- Call routing -- Dial Plan Installer - Select the Dial Plan and click Uninstall - Restart CCM Service
Thanks for your reply.
The path in CCM6.0 for locale is /common/log/taos-log-a/installed_options/cm-locale-fr_FR-6.0.0.1-1.cop
Is there a procedure to uninstall language locales?
Hi all,
I'm in the same situation. I'd like to delete the german cm-locale; how can I proceed?
I've a CUCM in version 7.1 :-)
Martin Schoonbroodt
DiData
Currently there is no way to do this other than reinstalling the system, there is an enhancement for this:
CSCsy15995
Cust need way to uninstall locales to avoid out of space issues
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
