dial peer not working
Joli Martinez
I am new to dial-peers.  I need to create a rule that would prepped my called number with the carrier's prefix.  If the user dials a 1 I would like to keep it if not add the 1.
So my call is user1 dials 2223334444 I need it to get translated to 12345*1222333444 before reaching the carrier, but also if user2 dials 15556667777 I need it to get translated to 12345*15556667777.
Not sure If I need two translations or just one.
The following is not working for me:
dial-peer voice 103 voip
 description 10 Digit Dialing
 destination-pattern [2-9].........
 progress_ind setup enable 3
 codec g711ulaw
 session protocol sipv2
 dtmf-relay rtp-nte
 session target dns:sip.provider.com
 translation-profile outgoing ADD612345*1
 session transport udp
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
 voice translation-rule 10
  rule 1 // /12345*1/
voice translation-profile ADD12345*1
translate called 1
Muhammad Awais Khan
hi,
your translation rule seems to be fine, you can further confirm this also with
Router#test voice translation-rule 10 2223334444
But my question here is about your carrier, carrier will accept the dialing pattern like 12345*….. in a single invite ?
Yes that is how my provider wants the number dialed.  I see that it is working when I do the test, but when I call the number it does not get translated.  The number I call gets forward without any translations to the provider.  Is it not matching the correct dial-peer?  I have a catchall inbound to my Pots lines then the outbound dial-peers, they are as follows:
dial-peer voice 100 voip
description CatchAll Incomming
destination-pattern +1T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 201 pots
destination-pattern 13052227925
port 1/0/0
dial-peer voice 101 voip
description Service Number (911, 411, etc)
destination-pattern [2-9]11
session target ipv4:10.21.10.4
no vad
dial-peer voice 102 voip
description 11 Digit dialing
destination-pattern 1[2-9].........
dtmf-relay rtp-nte
codec g711ulaw
no vad
translation-profile outgoing ADD12345*1
dtmf-relay rtp-nte
codec g711ulaw
no vad
figured it out.
