Dial plan with prefix 9
I'm trying to understand how my organization's dial plan works.
I dial the 7 digit extension (local calls) by adding a prefix 9. when the called party's phone is ringing, I see on my Phone's display that the 7 digit becomes a 10 digit. I don't really know where to look at and what is it that adds the area code. Can anyone please tell me where I need to look at on CCM4.2.
Jaime Valencia
call transformation can be performed using the external phone party mask on the DN config, can be done on translation patterns, route patterns, route list level and finally at the GW level.
check all those
it also might be that the telco is the one adding that, but you would need to get a debug from the GW to verify you're only sending 7 digits
javalenc
if this helps, please rate
java
Jaime Valencia
check all those
javalenc
java
thanks Jamie, I looked into the route pattern configuration page and it was listed under called party transformatons. really appreciate your quick response.
