Does MCS 7835I3 work with CCM version 6.1(2)?
Ameen Jwarneh
Does
Does the install DVD of 7825 work for 7835?
Joseph Martini
The installation DVD should work with any model server as long as the server is supported for 6.1.2, here's the matrix if you know the full server model to see if it supports 6.1.2: http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
It would also be a good idea once 6.1.2 is installed to upgrade to 6.1.5 due to known bugs on 6.1.2, especially the change notification issue CSCso93220.
