11-28-2011 01:22 AM - edited 03-16-2019 08:15 AM
I dear im facing a big issue here.
I have a CCME 7.1 running IOS c2900-universalk9-mz.SPA.150-1.M6.bin. This CCME is connected to PSTN using BRI interfaces for outbound and inbound public phone calls. The company also needs to make some calls to a SIP server ( a kind of IVR) over a sip trunk that is beyond the wan VSAT link.
When I make the call using some SCCP and SIP phones registered on the CCME, I can send DTMF to the IVR system but when the call comes from PSTN via BRI the call gets connected but i cant send DTMF to the IVR system.
On the first attempt neither phones (PSTN or internal) were able to call this IVR but I had to configure software MTP and the internal phones could call the IVR system over WAN VSAT link.
This is the configuration of the CCME. Check also the attachment
sh running-config
Building configuration...
network-clock-participate wic 0
network-clock-participate wic 1
isdn switch-type basic-net3
trunk group AAA_MOBILE_BRI
hunt-scheme longest-idle
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no telephony-service ccm-compatible
sip
registrar server
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice register global
mode cme
source-address 172.16.X.250 port 5060
timeouts interdigit 4
max-dn 40
max-pool 20
timezone 29
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 000342051580142A
voice register dn 6
number 255
name 255
label 255
voice register pool 6
id mac 0000.0000.0005
number 1 dn 6
dtmf-relay rtp-nte
username 255 password 255
codec g711ulaw
voice hunt-group 1 sequential
final 3000
list 254,253,252,251,250
pilot 3000
interface GigabitEthernet0/0
description LINK-TO-SW-AAA-SEDE-01
ip address 172.16.X.250 255.255.255.0
duplex full
speed 1000
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.X.250
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group AAA_MOBILE_BRI
interface BRI0/0/1
no ip address
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
ip route 0.0.0.0 0.0.0.0 172.16.X.254
voice-port 0/0/0
compand-type a-law
cptone PT
voice-port 0/0/1
compand-type a-law
cptone PT
voice-port 0/1/0
compand-type a-law
cptone PT
voice-port 0/1/1
compand-type a-law
cptone PT
sccp local GigabitEthernet0/0
sccp ccm 172.16.X.250 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register MTPAAA
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 mtp
description MTPAAA
codec g711ulaw
maximum sessions software 100
associate application SCCP
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 300 voip
description ----- SIPTrunk to OneContact -----
destination-pattern 6...
session protocol sipv2
session target ipv4:A.B.C.19
voice-class codec 2
dtmf-relay rtp-nte sip-notify
no vad
telephony-service
sdspfarm units 1
sdspfarm tag 1 MTPAAA
max-ephones 25
max-dn 50
ip source-address 172.16.X.250 port 2000
system message AAAA
cnf-file location flash:
cnf-file perphone
user-locale PT
network-locale PT
load 7937 apps37sccp.1-2-1-0.bin
time-zone 29
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern 2..
moh music-on-hold.au
transfer-system full-consult
transfer-pattern 2..
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Redial Newcall Dnd Cfwdall Pickup
softkeys alerting Endcall Callback
softkeys connected Endcall Hold Trnsfer Park Confrn
softkeys ringing Answer Dnd
ephone-dn 1 dual-line
number 200
description YYYY
name YYYY
corlist incoming Class-30
ephone-dn 2 dual-line
number 201
pickup-group 298
description KKKK
name KKKK
corlist incoming Class-40
ephone 1
mac-address 6C50.4DDA.5528
ephone-template 1
type 7962
button 1:1 2w2 3w3 4w4
button 5w5
ephone 2
mac-address E8BA.70FA.7387
ephone-template 1
type 7911
button 1:2
11-29-2011 05:04 AM
Dear Adam and Carlo,
I have found the problem, the provider is not sending the DTMFs, I have tried another provider and everything was ok.
So now Im trying to see it with them.
Many thanks for your help.
Com as melhores saudações
Zacarias Nhancune-Netwoking Engineer-CCNP,CCNA,CCNA Voice -11183622
12-23-2011 01:57 AM
Hi dear,
I have another issue. Please help:
Im running a CUCM Business Edition 6.1 (2) and after a hard reset it say:
/common contains a file system with errors, check forced
/common Inodes that were part of a corrupted orphan link list found.
/common: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY (i.e. without -a or -p options)
/grub: clean, 26/66520 files, 16820/265072 blocks
/partB: clean, 11/3515680 files, 118535/7018396 blocks
An error occured during the file system check.
Dropping you to a shell; the system will reboot
when you leave the shell.
Give root password for maintenance
(or type Control-D to continue):
11-29-2011 01:03 AM
11-29-2011 12:27 AM
Hi.
Did you try to set g711ulaw codec to your DP 300?
Can you also attach a trace of a call from an IP phone?
Carlo
11-29-2011 12:51 AM
12-23-2011 01:57 AM
Hi dear,
