Kope,
You will receive an RAI alarm when the far end is
is not receiving data/clocking properly or in error.
The RAI is the signal the far end sends to you to
alert you to this.
If this is always occurring there is a problem in
your transmit path to the next hop.
Check you are using the correct framing method for your link
For E1 this is either CRC4 or No-CRC4.
If this is only happening now and then it would seem more like
an intermittant line fault.
You DO need to know how the other end is set up.
Sorry I cant tell you much more.
Alex.
Please rate useful posts.
Alex.
