01-21-2013 04:48 PM - edited 03-16-2019 03:17 PM
Hi Guys
I have a issue with a E1 R2. The calls from and to PSTN using the E1 R2 and not negotiate the codec G711,only use the codec g729.
I´ve change the class code using G711a and G711u only, but the call get a congestion. I have a E1 PRI in the same GW and the calls using G711, no problem.
This is the configuration:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
dial-peer voice 8600 voip
destination-pattern 86..
session target ipv4:SUB1
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 8601 voip
preference 2
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 100 pots
destination-pattern 9T
incoming called-number .
fax rate disable
direct-inward-dial
port 0/0/1:0
Any idea?
TIA
Cristian
01-22-2013 01:58 AM
Christian,
On the CUCM admin pages.
Check the region that your gateway is in supports G711.
Also check the location for bandwidth, is there enough BW set to
allow G711 ,
Roughly
24K per G729 call
80K per G711 call.
Alex.
Please rate useful posts.
01-22-2013 07:21 AM
Thank you Alex, but the GW are in the same region that the IP Phones (G722-G711) and when the call use the E1 PRI negotiate using the class codec configured in the GW.
There are a command necessary for to do fixed to use G711 the E1 R2?
TIA
Cristian
01-22-2013 08:19 AM
Christian,
Can you look at the gateway config page on your CUCM.
Have you enable FastStart for inbound and outbound ?
That may be stopping the negotiation as you select a codec to use.
Try disabling FastStart if it is set
Alex.
01-22-2013 01:16 PM
Dear Alex
Enable Inbound FastStart and Enable Outbound FastStart are disable.
TIA
Cristian
01-22-2013 01:34 PM
Christian,
debug cch323 h245
and make a test call
Alex.
