Erase Cisco 29XX , 39XX to factory Default ?
Sam Nk
What is the best way to wipe out the Routers configuration and bring it to Factory default mode?
erase startup config ? or any other advance commands available ?
I wanted to make sure there should not be any configuration on the device post this task.
Sam.
Find below links helpful
https://supportforums.cisco.com/document/11856/resetting-router-factory-default-removing-startup-configuration-file
https://dcloud-cms.cisco.com/help/reset-router
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Leo Laohoo
Format the CF.
Hello sir,
Could you suggest?
I believe the 2900 and 3900 also comes with a RESET button.
Abhay
Abhay Singh Reyal
