Error opening tftp://.......................(timed out) UC500 loopback network
jason
Hello all,
When I try to access areas through CCA (cisco configuration assistant) such as ringtones or backgrounds for the phones, I get an error message. I have attached a screenshot of the error I get
Anyone have any idea as to how I can fix this?
16 Replies 16
Jason,
Firstly thanks for you patience.
We have located the issue to the default gateway of the PC not having ip routes to UC500/CUE.
So it is not always thye rocket science that is the issue.
Alex
Please rate and mark as correct answer if this helped
Regards, Alex. Please rate useful posts.
Thank you for the prompt responses. I couldn't have asked for better help
Jason
