fax dial-peer not working
Joli Martinez
I have created the following dial-peer.  This is only used for outbound faxing, inbound comes in via a fax2email server.  When I attempt to dial out the call never connects and as far as I can tell it is because of a codec issue, but not really sure how to read the debug.
dial-peer voice 102 voip
 description 11 Digit dialing
 translation-profile outgoing E164
 destination-pattern 1[2-9].........
 progress_ind setup enable 3
 session protocol sipv2
 session target dns:sip.flowroute.com
 session transport udp
 dtmf-relay rtp-nte
 codec g711ulaw
 fax-relay ecm disable
 fax-relay sg3-to-g3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
################## Debug ##################
Mar 16 17:46:56.297: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=73
Mar 16 17:46:56.297: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  73)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Mar 16 17:46:56.297: //73/F227CBEB80ED/SIP/Info/sipSPIUpdateCallEntry:
Call 73 set InfoType to SPEECH
Mar 16 17:46:56.301: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:12345*17778889999@sip.provider.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK2669B
Remote-Party-ID: <sip:13334445555@10.21.10.12>;party=calling;screen=no;privacy=off
From: <sip:13334445555@10.21.10.12>;tag=94024FC-94F
To: <sip:12345*17778889999@sip.provider.com>
Date: Mon, 16 Mar 2020 17:46:56 GMT
Call-ID: F688689C-66E411EA-80F2AE40-46C6A4E2@10.21.10.12
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4062694379-1726222826-2163060288-1187423458
User-Agent: Cisco-SIPGateway/IOS-15.2.1.T3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1584380816
Contact: <sip:13334445555@10.21.10.12:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 9995 228 IN IP4 10.21.10.12
s=SIP Call
c=IN IP4 10.21.10.12
t=0 0
m=audio 28022 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Mar 16 17:46:56.797: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not an Forked leg..
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Info/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
SIP: (73) Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Info/sipSPISendInvite: Associated container=0x31CA3790 to Invite
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x2C520714, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:46:56.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:46:56.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2C520714
Mar 16 17:46:56.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2C520714, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:46:56.797: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Mar 16 17:46:57.797: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not an Forked leg..
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Info/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Info/sipSPISendInvite: Associated container=0x31CA3790 to Invite
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x2C520714, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:46:57.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:46:57.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2C520714
Mar 16 17:46:57.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2C520714, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:46:57.797: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 16 Mar 2020 17:46:57 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1584380817
Expires: 180
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Mar 16 17:46:58.313: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:12345*17778889999@sip.provider.com>;tag=gK0aaa1ec4
Via: SIP/2.0/UDP 10.21.10.12:5060;rport=63967;received=107.211.204.153;branch=z9hG4bK2669B
CSeq: 101 INVITE
Record-Route: <sip:69.18.5.7:5060;lr>
Record-Route: <sip:69.18.5.8:5060;lr>
Contact: <sip:+17778889999@107.17.5.140:5060>
Content-Length:  171
v=0
o=- 25797 29915 IN IP4 107.17.5.42
s=-
c=IN IP4 107.17.5.42
t=0 0
m=audio 26864 RTP/AVP 0 101
a=fmtp:101 0-15
a=maxptime:20
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Error/sipSPICheckReliableProvStringtag: Unable to access supported header values
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 26864
SIP: Attribute mid, level 1 instance 1 not found.
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.21.10.12
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=107.17.5.42, dest_port=26864
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP, event:E_SIP_IWF_EV_CALL_BRIDGE
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711ulaw, bytes :160
Preferred  DTMF relay  : rtp-nte
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_INVITE_RESP_SDP_RCVD
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_incoming_invite_resp_answer_valid:  - 1
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_common_answer_rcvd_hdlr:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_network_event:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP, event:E_SIP_IWF_EV_RCVD_SDP
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_ed_rcvd_sdp_answer_hdlr:
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_DONE
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE
 Stream type            : voice+dtmf
 Media line             : 1
 State                  : STREAM_ADDING (2)
 Stream address type    : 1
 Callid                 : 73
 Negotiated Codec       : g711ulaw, bytes :160
 Nego. Codec payload    : 0 (tx), 0 (rx)
 Negotiated DTMF relay  : rtp-nte
 Negotiated NTE payload : 101 (tx), 101 (rx)
 Negotiated CN payload  : 0
 Media Srce Addr/Port   : [10.21.10.12]:28022
 Media Dest Addr/Port   : [107.17.5.42]:26864
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Mar 16 17:46:58.317: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
Mar 16 17:46:58.317: //73/F227CBEB80ED/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_bridge: confID = 8, srcCallID = 73, dstCallID = 72
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 73/72
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=73, new streamcallid=73
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_BRIDGE
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 625207628, ccb xmitFunc = 625207628
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 73) to the VOIP RTP library
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.21.10.12
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.21.10.12, lport = 28022, raddr = 107.17.5.42, rport=26864, do_rtcp=TRUE
src_callid = 73, dest_callid = 72, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 107.17.5.42, vrf tableid = 0 media_addr_type = 1
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:307C6E04
Mar 16 17:46:58.321: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=73
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_is_escalation: local channels = 0, peer channels = 0
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  73)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_bridge: really can't find peer_stream for
                                                dtmf-relay interworking
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_peer_event:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 27
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_PEER_CAPS
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sccp_do_video:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_peer_caps_ind_hdlr:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=73, current_seq_num=0x867
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=73, current_seq_num=0x424
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_process_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_process_caps_ind: Set forking flag to 0x0
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=1, from CLI config=0
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=72
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 0x2AC51700 (gccb)
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_process_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_process_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x201
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_process_caps_ind: Calling cc_api_caps_ack()
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 7
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IPIPMS:cur_container:ccsip_ipip_media_service_main_container, cur_state:S_IPIP_MEDIA_SERV_STATE_IDLE, event:E_IPIP_MEDIA_SERV_EV_PEER_CAPS_IND
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_map_cc_return_code: Mapping SIP_IWF_SUCCESS
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 28
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_PEER_CAPS_ACK,
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_def_peer_caps_ack_hdlr:
Mar 16 17:46:58.321: //73/F227CBEB80ED/SIP/Info/sip_iwf_tdm_process_caps_ack: Set forking flag to 0x7
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:46:58.745: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Session-Expires: 3600;refresher=uas
Content-Length:  171
Supported: timer
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=maxptime:20
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_BRIDGE
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:31CA3EC8
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 3600 refresher: uas
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLSRRespRcvd: Session expires params received starting the timer based on the refresher
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLStartSessionTimer: Started Session Expiry Timer with duration:3568000
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
SE: 3600;refresher:uas peer refresher:none, flags:0, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 26864
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.21.10.12
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=26864 new=26864
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : Yes
New Media              : No
DSP DNLD Reqd          : No
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, event:E_SIP_INVITE_RESP_SDP_RCVD
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_invite_resp_ignored:
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_ignore_hdlr: S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, E_SIP_INVITE_RESP_SDP_RCVD
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:CNFSM_NO_STATE_CHANGE
 Media line             : 1
 State                  : STREAM_ACTIVE (5)
 Callid                 : 73
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
Mar 16 17:46:58.749: //73/F227CBEB80ED/SIP/Info/sipSPIQoSRevertBW: Entry
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Mar 16 17:46:58.749: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/sipSPIShrlCall: Check peer: 102 for Shared-Line call, callid: 73
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/sipSPIOptionsPing: Session Timer negotiated, not doing Options Ping
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE, event:E_SIP_DIALOG_ESTD
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_dialog_established_hdlr:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_ACTIVE
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sip:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h323:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h32x:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/is_mode_sip_default:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_set_tdm_ip_call_active:
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_mid_dialog_container
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_IDLE
Mar 16 17:46:58.753: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Info/sipSPISendAck: Associated container=0x31CA3738 to Ack
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x2AC56328, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x2534B320
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:46:58.753: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0ACK sip:+17778889999@107.17.5.140:5060 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK271F07
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mar 16 17:47:00.885: //73/F227CBEB80ED/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=73, proc_id=9
Mar 16 17:47:03.701: //73/F227CBEB80ED/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=73, proc_id=9
Mar 16 17:47:07.253: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_T38_FAX_START
Mar 16 17:47:07.253: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_feature: Ignoring non-hookflash feature event (0x00000001)
Mar 16 17:47:07.253: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 19
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/act_active_t38_fax_start: Entering T.38 mode
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/act_active_t38_fax_start: Transaction active. CCAPI events will be queued.
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/sipSPIUpdateStreamQoSAttributes: 9 a-line(s) found for stream 1
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
Mar 16 17:47:07.253: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 69.18.5.8,Port 5060, Transport 1, SentBy Port 5060
Mar 16 17:47:07.253: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:31CA3BB0
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLSRReqSend: Sending previously negotiated session expires params
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
SE: 3600;refresher:uas peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_network_event:
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_SENT_SDP
Mar 16 17:47:07.253: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_OFFER_SENT
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not an Forked leg..
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Mar 16 17:47:07.257: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/sipSPISendInvite: Associated container=0x31CA3BB0 to Invite
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CFAD18, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x253492B0
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:07.257: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:07.257: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CFAD18
Mar 16 17:47:07.257: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CFAD18, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
Mar 16 17:47:07.257: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+17778889999@107.17.5.140:5060 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK28185
Date: Mon, 16 Mar 2020 17:47:07 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1584380827
Expires: 180
Content-Length: 314
v=0
o=CiscoSystemsSIP-GW-UserAgent 9995 229 IN IP4 10.21.10.12
s=SIP Call
t=0 0
m=image 28022 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Mar 16 17:47:07.257: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_feature: Ignoring non-hookflash feature event (0x00000001)
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not an Forked leg..
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Info/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Info/sipSPISendInvite: Associated container=0x31CA3BB0 to Invite
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CFAD18, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CFAD18
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CFAD18, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:47:08.081: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:47:08.081: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.21.10.12:5060;rport=63967;received=107.211.204.153;branch=z9hG4bK28185
CSeq: 102 INVITE
Record-Route: <sip:69.18.5.8:5060;lr;did=945.c6e4>
Content-Length:  171
Supported: timer
v=0
o=- 25797 29916 IN IP4 107.17.5.42
s=-
t=0 0
m=image 26864 udptl t38
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:31CA35D8
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLSRRespRcvd: Session expires params received starting the timer based on the refresher
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLStartSessionTimer: Started Session Expiry Timer with duration:3568000
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 26864
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.21.10.12
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIDoFaxAttributeNegotiation: No remote bit rate, Using our bit rate: 14400
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIDoFaxMediaNegotiation: T.38 negotiated
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=26864 new=26864
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareMediaType: Media type switching from 0 to 11 for stream 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: negotiated codec changed from g711ulaw to T38Fax
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: negotiated dtmf relay changed from rtp-nte to inband-voice
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=Yes
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Type Change Identified
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Codec Change Identified
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media            : No
Delayed Media          : No
Bridge Done            : Yes
New Media              : Yes
DSP DNLD Reqd          : Yes
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_OFFER_SENT, event:E_SIP_INVITE_RESP_SDP_RCVD
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_incoming_invite_resp_answer_valid:  - 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_common_answer_rcvd_hdlr:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_network_event:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_RCVD_SDP
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_IDLE
 Media line             : 1
 State                  : STREAM_CHANGING (4)
 Callid                 : -1
 Negotiated Codec       : T38Fax, bytes :20
 Nego. Codec payload    : 255 (tx), 255 (rx)
 Negotiated DTMF relay  : inband-voice
 Negotiated NTE payload : 0 (tx), 0 (rx)
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIDestroyRtpSession: stream:31CF0CD8
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 73) to the VOIP RTP library
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.21.10.12, lport = 28022, raddr = 107.17.5.42, rport=26864, do_rtcp=FALSE
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPICreateRtpSession: sess: 2BA2015C do_rtcp:0
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPICreateRtpSession: stun is disabled
Mar 16 17:47:08.085: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=73
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_is_escalation: local channels = 0, peer channels = 0
retVal = 0
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  73)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:31CF0CD8
retVal = 0
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_LOCAL_CAPS_IND
Mar 16 17:47:08.085: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sccp_do_video:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_iwf_common_local_caps_hdlr:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=73, current_seq_num=0x424
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=73, current_seq_num=0x22AB
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: T38Fax, Bytes=20
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec T38Fax
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 0x2AC51700 (gccb)
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=72
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_XACTION_RESUME
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sip_iwf_common_ignore_hdlr:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_IDLE, event:E_SIP_DIALOG_ESTD
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_dialog_established_hdlr:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_ACTIVE
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sip:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h323:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h32x:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/is_mode_sip_default:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_set_tdm_ip_call_active:
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_mid_dialog_container
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Mar 16 17:47:08.089: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPISendAck: Associated container=0x31CA3EC8 to Ack
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x2C546A88, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x2534B320
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:08.089: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:08.089: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2C546A88
Mar 16 17:47:08.089: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2C546A88, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x31C52D70
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 13334445555
Called Number            : 12345*17778889999
Source IP Address (Sig  ): 10.21.10.12
Destn SIP Req Addr:Port  : 69.18.5.8:5060
Destn SIP Resp Addr:Port : 69.18.5.8:5060
Destination Name         : sip.provider.com
Mar 16 17:47:08.089: //73/F227CBEB80ED/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 20
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.21.10.12
Source IP Port    (Media): 28022
Destn  IP Address (Media): 107.17.5.42
Destn  IP Port    (Media): 26864
Orig Destn IP Address:Port (Media): [ - ]:0
Mar 16 17:47:08.101: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CODEC_LOCAL_DNLD_DONE
Mar 16 17:47:08.101: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 21
Mar 16 17:47:08.101: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 16 Mar 2020 17:47:08 GMT
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1584380828
Expires: 180
Content-Length: 314
v=0
s=SIP Call
t=0 0
a=T38FaxVersion:0
Sent:
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK29169C
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Mar 16 17:47:08.265: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length:  171
Supported: timer
v=0
s=-
t=0 0
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Info/sipSPISendAck: Associated container=0x31CA3EC8 to Ack
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CFAD18, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:08.269: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CFAD18
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CFAD18, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Mar 16 17:47:08.269: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length:  171
ContACK sip:+17778889999@107.17.5.140:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Mar 16 17:47:32.705: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_T38_FAX_DONE
Mar 16 17:47:32.705: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 20
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/act_active_t38_fax_done: Exiting T.38 mode
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/act_active_t38_fax_done: Transaction active. CCAPI events will be queued.
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/sipSPIUpdateStreamQoSAttributes: 4 a-line(s) found for stream 1
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/sipSPICacheEvent: Free'd ccb's cached Event
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
Mar 16 17:47:32.705: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)
Mar 16 17:47:32.705: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 69.18.5.8,Port 5060, Transport 1, SentBy Port 5060
Mar 16 17:47:32.705: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:31CA3108
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLSRReqSend: Sending previously negotiated session expires params
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_network_event:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_SENT_SDP
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_OFFER_SENT
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_get_forked_recording_data: MF: Not an Forked leg..
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/sipSPICreateRecParticipantHeaders: X-Cisco-Recording-Participant header not added.
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Mar 16 17:47:32.709: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr> Group (a= group line) attribute, level 65535 instance 1 not found.
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/sipSPISendInvite: Associated container=0x31CA3108 to Invite
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x2AC2EC24, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x253492B0
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:32.709: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:32.709: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2AC2EC24
Mar 16 17:47:32.709: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2AC2EC24, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Info/sentInviteRequest: Sent Invite in state STATE_SEND_MIDCALL_INVITE_PENDING
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_SEND_MIDCALL_INVITE_PENDING, SUBSTATE_NONE)  to (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)
Mar 16 17:47:32.709: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK2A25A4
Remote-Party-ID: <sip:13334445555@10.21.10.12>;party=calling;screen=no;privacy=off
From: <sip:13334445555@10.21.10.12>;tag=94024FC-94F
Date: Mon, 16 Mar 2020 17:47:32 GMT
Call-ID: F688689C-66E411EA-80F2AE40-46C6A4E2@10.21.10.12
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4062694379-1726222826-2163060288-1187423458
User-Agent: Cisco-SIPGateway/IOS-15.2.1.T3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 103 INVITE
Max-Forwards: 70
Timestamp: 1584380852
Contact: <sip:13334445555@10.21.10.12:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 243
v=0
s=SIP Call
c=IN IP4 10.21.10.12
t=0 0
m=audio 28022 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Mar 16 17:47:32.717: //73/F227CBEB80ED/SIP/Info/ccsip_modify_media_ind: codec=0x1 modem_redundancy=0 callID 73 peer callID 72
Mar 16 17:47:32.717: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_MEDIA_CHANGED
Mar 16 17:47:32.717: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 18
Mar 16 17:47:32.717: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Mar 16 17:47:32.717: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
Mar 16 17:47:32.717: //73/F227CBEB80ED/SIP/Info/sipSPIEnqueueBufferEvent: Event SIPSPI_EV_CC_CALL_MEDIA_CHANGED queued on buffer queue.
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:47:32.925: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:12345*17778889999@sip.provider.com>;tag=gK0aaa1ec4
Via: SIP/2.0/UDP 10.21.10.12:5060;rport=63967;received=107.211.204.153;branch=z9hG4bK2A25A4
CSeq: 103 INVITE
Record-Route: <sip:69.18.5.7:5060;lr>
Contact: <sip:+17778889999@107.17.5.140:5060>
Content-Length:  171
Supported: timer
v=0
o=- 25797 29917 IN IP4 107.17.5.42
s=-
c=IN IP4 107.17.5.42
t=0 0
m=audio 26864 RTP/AVP 0 101
a=fmtp:101 0-15
a=maxptime:20
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/ccsip_api_response_answer: ccsip_api_response_answer.
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:31CA3CB8
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLSRRespRcvd: Session expires params received starting the timer based on the refresher
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLStartSessionTimer: Started Session Expiry Timer with duration:3568000
Mar 16 17:47:32.925: //73/F227CBEB80ED/SIP/Info/Session-Timer/sipSTSLMain:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 26864
SIP: Attribute mid, level 1 instance 1 not found.
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.21.10.12
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=107.17.5.42, dest_port=26864
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=26864 new=26864
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareMediaType: Media type switching from 11 to 0 for stream 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: negotiated codec changed from T38Fax to g711ulaw
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: negotiated dtmf relay changed from inband-voice to rtp-nte
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=Yes
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Type Change Identified
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Codec Change Identified
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIRSVPCompareSDP: Media Offer Changed
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711ulaw, bytes :160
Preferred  DTMF relay  : rtp-nte
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : Yes
New Media              : Yes
DSP DNLD Reqd          : Yes
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_OFFER_SENT, event:E_SIP_INVITE_RESP_SDP_RCVD
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_is_incoming_invite_resp_answer_valid:  - 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_common_answer_rcvd_hdlr:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_network_event:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_RCVD_SDP
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_MID_DIALOG_IDLE
 Stream type            : voice+dtmf
 Media line             : 1
 Stream address type    : 1
 Callid                 : -1
 Negotiated Codec       : g711ulaw, bytes :160
 Nego. Codec payload    : 0 (tx), 0 (rx)
 Negotiated DTMF relay  : rtp-nte
 Negotiated NTE payload : 101 (tx), 101 (rx)
 Negotiated CN payload  : 0
 Media Srce Addr/Port   : [10.21.10.12]:28022
 Media Dest Addr/Port   : [107.17.5.42]:26864
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIDestroyRtpSession: stream:307C6E04
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 73) to the VOIP RTP library
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.21.10.12, lport = 28022, raddr = 107.17.5.42, rport=26864, do_rtcp=TRUE
src_callid = 73, dest_callid = 72, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 107.17.5.42, vrf tableid = 0 media_addr_type = 1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPICreateRtpSession: sess: 2BA2015C do_rtcp:1
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Media/sipSPICreateRtpSession: stun is disabled
Mar 16 17:47:32.929: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=73
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_is_escalation: local channels = 0, peer channels = 0
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
Mar 16 17:47:32.929: //73/F227CBEB80ED/SIP/State/sipSPIChangeStreamState: Stream (callid =  73)  State changed from (STREAM_CHANGING) to (STREAM_ACTIVE)
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:307C6E04
Mar 16 17:47:32.933: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIUpdateRtcpSession: VQM: gccb=0x0, gccb->callId=0, ccb->ccCallID=73
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_is_escalation: local channels = 0, peer channels = 0
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_handle_generic_event:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_process_event:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_LOCAL_CAPS_IND
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sccp_do_video:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_iwf_common_local_caps_hdlr:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=73, current_seq_num=0x22AB
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=73, current_seq_num=0xF2B
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_do_caps_ind_internal: Load DSP with codec: g711ulaw, Bytes=160
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Media/sipSPISetStreamInfo: 0x2AC51700 (gccb)
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=72
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_api_response_answer: Modified QoS params INVITE
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_XACTION_RESUME
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sip_iwf_common_ignore_hdlr:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sact_sent_mid_invite_new_message_response: ccsip_api_response_answer return value: SIP_SUCCESS
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_handle_call_active:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_process_event:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_MID_DIALOG_IDLE, event:E_SIP_DIALOG_ESTD
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_dialog_established_hdlr:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_mid_dialog_container, cur_state:S_SIP_IWF_SDP_DONE, event:E_SIP_IWF_EV_CALL_ACTIVE
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/is_mode_sip_sip:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h323:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/is_mode_sip_h32x:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/is_mode_sip_default:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_set_tdm_ip_call_active:
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_default_mid_dialog_container
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/ccsip_cnfsm_debugs: OA:next_state:CNFSM_NO_STATE_CHANGE
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Mar 16 17:47:32.933: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPISendAck: Associated container=0x31CA35D8 to Ack
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CF35D0, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x2534B320
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:32.933: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:32.933: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CF35D0
Mar 16 17:47:32.933: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CF35D0, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_SENT_MIDCALL_INVITE, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Mar 16 17:47:32.933: //73/F227CBEB80ED/SIP/Info/sipSPISendAckForMidCallInvite: Transaction Complete. Lock on Facilities released.
Mar 16 17:47:32.937: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK2B110
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
Mar 16 17:47:34.597: //73/F227CBEB80ED/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:307C6E04
Mar 16 17:47:34.613: //73/F227CBEB80ED/SIP/Info/ccsip_call_statistics: Requesting stats for callid=73
Mar 16 17:47:34.613: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 29
Mar 16 17:47:34.613: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 16 17:47:34.613: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
Mar 16 17:47:34.613: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 16 17:47:34.617: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 16 17:47:34.617: //73/F227CBEB80ED/SIP/Info/act_active_disconnect: Disconnect deferred, as stats request pending
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=73, proc_id=1
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 29
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/ccsip_ipip_media_forking_post_event: MF: Not a Anchor SIP leg..
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/sipSPISendBye: Associated container=0x31CA3B58 to Bye
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CF35D0, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x2534A8A4
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CF35D0
Mar 16 17:47:34.821: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CF35D0, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
Mar 16 17:47:34.821: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Mar 16 17:47:34.825: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+17778889999@107.17.5.140:5060 SIP/2.0
Via: SIP/2.0/UDP 10.21.10.12:5060;branch=z9hG4bK2C3CA
Max-Forwards: 70
Timestamp: 1584380854
CSeq: 104 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=737,OS=93125,PR=459,OR=73440,PL=0,JI=1,LA=0,DU=36
Content-Length: 0
Mar 16 17:47:35.593: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Mar 16 17:47:35.593: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddRouteHeaders: status = TRUE Route: <sip:69.18.5.8:5060;lr>,<sip:69.18.5.7:5060;lr>
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Info/sipSPISendBye: Associated container=0x31CA3B58 to Bye
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: msg=0x31CF35D0, addr=69.18.5.8, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Mar 16 17:47:35.593: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:69.18.5.8, rport:5060 with laddr:
Mar 16 17:47:35.593: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: gcb=0x31C52D70 is already on connection=0x31598EF4 context_list
Mar 16 17:47:35.593: //73/F227CBEB80ED/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31CF35D0
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31CF35D0, addr=69.18.5.8, port=5060, local_addr=, connId=2 for UDP
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK2C3CA from via branch list
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.21.10.12:5060;rport=63967;received=107.211.204.153;branch=z9hG4bK2C3CA
CSeq: 104 BYE
Record-Route: <sip:69.18.5.8:5060;lr>
Content-Length: 0
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 5290 DiscTime:15523801 ConnTime 15520117
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Media/sipSPIDestroyRtpSession: stream:307C6E04
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/State/sipSPIChangeState: 0x31C52D70 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 49
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[47] removed.
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x31C52D70 key=F688689C-66E411EA-80F2AE40-46C6A4E2@10.21.10.12
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, unregistering context=0x31C52D70
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstancePurgeContextInConnection: Purging context gcb=0x31C52D70 from the connection=0x31598EF4 context list
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/ccsip_offer_ans_delete:
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/ccsip_iwf_delete:
Mar 16 17:47:35.597: //73/F227CBEB80ED/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 31C52D70
Mar 16 17:47:35.597: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[47]
Mar 16 17:47:35.601: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1584380855
CSeq: 104 BYE
Content-Length: 0
Mar 16 17:47:35.969: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [69.18.5.8]:5060, local_address:[ - ]
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2BDDC50C
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2BDDC50C, addr=69.18.5.8, port=5060, local_addr=, connid=2, transport=UDP
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 2
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 104 BYE
Content-Length: 0
Mar 16 17:47:35.973: //-1/xxxxxxxxxxxx/SIP/Error/sipSPILocateInviteDialogCCB: Could not find ccb for response
0 Replies 0
