FAX relay in CallManager
shikamarunara
Level 4
Level 4
Someone mentioned to me that there is an alternate method to configuring fax for CM than setting up a FAX machine with an ATA. Is it possible to configure a gateway to recieve a fax and send it to a mail relay?
-Shikamaru
davidme
Yeah you can setup T37 store and forward. You basically configure dial peers on your gateway to deliver to email addresses.
Have a look at the link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008053b58e.html
